Old 12-18-2004, 03:54 AM   #1
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
tranny problem th350
i was driving my truck and when it went to shift to 3rd it started slipping like it was in neutral and would start bogging down and when i gave it some throttle it would start shifting back and forth between 2nd and 3rd, and 3rd would slip like crazy. when i give it enough gas to kick the tranny down it goes into 1st and then shifts to 3rd really hard skipping 2nd. and when i give it alot of gas it wont shift at all. it also is making a rattling sound and i would assumethat is a bad sign. apparently 500 ft lbs of torque and constantly driving it like i stole it was too much for it, 2nd trans this year tranny is only 3 months old with about 4,000 miles last trans lasted for a year with this motor
sorry for long post
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 12-18-2004, 10:13 AM   #2
jmanz69
Careful, they attack...
jmanz69's Avatar
Yeah, 500ft/lbs with a TH-350 = Kaboom! Did you have the trans built for that much power? They can handle it if you have good parts put in. Otherwise I would go to a TH-400. The 350's aren't meant for that much abuse. You will keep replacing them if you don't switch. Good luck.
jmanz69 is offline   Reply With Quote
Old 12-18-2004, 12:31 PM   #3
71chevylongbed
Got Horsepower?
yeah i told the guy at the trans shop how much power it had and that i wanted to be able to hot rod the crap out of it and pull my horse trailer with it and he said "oh yeah it can handle it no problem" i guess that shows you how much he knows. i should have put in a manual
Old 12-18-2004, 12:41 PM   #4
jmanz69
jmanz69's Avatar
I wouldn't be pulling a horse trailer with a TH-350 period. They are fine for 1/2 ton trucks and pulling medium wieght trailers. You should definately go with a TH-400 or a 4L80E. The 4 speed would be way expensive though. Should be able to get a good 400 core and rebuild at a resonable price.
Old 12-18-2004, 12:59 PM   #5
imdarren
imdarren's Avatar
I would not waste any more time with the TH 350. Go with a TH 400, and have it built to the hilt. You will never need another tranny.
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 12-18-2004, 01:17 PM   #6
71chevylongbed
Got Horsepower?
Angry
yeah and i probably shouldnt floor it from every stop when i am pulling it. tranny has an 18 month 18,000 mile warranty so i will see how many more i can fry in that time period
Old 12-18-2004, 03:20 PM   #7
3 on the tree
This is probably a dumb question, but have you upgraded the cooling system for the tranny? I can remember when there were alot of Chevy trucks out there pulling everything with 350/350 combos. I was one of them. Had a 70 burb with 406/350 towed race cars with it, stock trailers etc. Never had a problem with stock tranny. It had a big aftermarket cooler plumbed in line with the radiator cooler. I beat on this thing till the body fell off, finally pulled the motor and put it in a blazer,along with the trans.
3 on the tree is offline   Reply With Quote
Old 12-18-2004, 05:24 PM   #8
71chevylongbed
Got Horsepower?
i put in another cooler after the radiator cooler and the line going back to the trans is pretty cool.
another question i have is what is rattling around inside the trans?
Old 12-18-2004, 05:40 PM   #9
c-1072
Cheap tow hooks
What do you guys think of my cheap tow hooks pretty flashy huh , i figured chrome is nice and for eight bucks how could i go wrong . :p
c-1072 is offline   Reply With Quote
Old 12-18-2004, 06:10 PM   #10
spencra
This, is my BOOMSTICK!
spencra's Avatar
Woh, that post came out of left field.
Larry
Got rid of my projects for now.
1980 Jeep CJ7
1998 Nissan Sentra (my car)
2001 Toyota Sienna (wife's, of course)
spencra is offline   Reply With Quote
Old 12-18-2004, 06:13 PM   #11
spencra
spencra's Avatar
Yeah, I would say go with the th400 for hauling stuff. It's meant for hauling and being abused.
THM350 - Medium duty 3 speed trans used from 1969 to 1989, Used in Buick, Olds, Pontiac and Chevrolet cars and Chevy & GMC light trucks until 1987. Generally used in straight and V6 and small block engines. Generally able to handle up to 400 foot pounds of torque
THM400 - The THM400 was GM's Heavy-duty 3 speed transmission used from 1964 to 1990. Used on large displacement, high torque engines and engines with towing packages. Generally found in Chevy & GM trucks, cadilacs and large displacement engined, full size GM rear wheel drive cars.
Larry
1980 Jeep CJ7
Old 12-18-2004, 09:24 PM   #12
Sweet72
Sweet72's Avatar
Cableguy0 has gone through a few in his truck too. A TH350 should be able to handle a hot street 350 for everyday driving. Now if you race and use nitrous or forced induction and are really twisting the hell out of it, of course it won't last for long. I find it hard to believe you're getting 500 ft. lbs. out of that motor.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 12-19-2004, 03:13 AM   #13
71chevylongbed
Got Horsepower?
i had it on a chassis dyno and it put out 226 hp and 456 ft lbs torque. so figuring for power lost through the driveline that should be about 300 hp and 500 ft lbs torque at the flywheel right?
Old 12-19-2004, 11:52 AM   #14
Sweet72
Sweet72's Avatar
That's one torquey engine you have there. Man, I was hoping for that kind of torque out of the 383 I'm building, now I may be disappointed if I don't achieve those numbers or better.
Old 12-19-2004, 12:47 PM   #15
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Did you try manually shifting it?
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 12-19-2004, 05:00 PM   #16
71chevylongbed
Got Horsepower?
yeah i tried manually shifting it and it will go into gear but when i give it gas it starts slipping. i took it for a quick drive yesterday and that rattling/grinding noise is worse than before so im guessing that i tore something up pretty good any ideas on what that noise might be?
Old 12-20-2004, 02:40 PM   #17
71chevylongbed
Got Horsepower?
ok so i take it down to the trans shop today and the guy asks me "have you been hot rodding it or racing stop light to stop light?" while he is asking me this i am thinking to myself does it really matter? and then he says that 500 ft lbs of torque may have done it in. read quote. and if that is the case then it is not covered by the warranty. then he goes on to tell me that the transmissions that they build for the drag race cars do not come with warrantys because hotrodding transmissions can cause them to fail at any time. they always seem to change their story when something breaks. all i know is that he said it could handle racing and towing and it came with the 18,000, 18 month warranty and if he wont honor that im going to be mad
Old 12-20-2004, 02:46 PM   #18
spencra
spencra's Avatar
Kick a$$ and take names my man.
If he can change his story than so can you. "Ah, no sir, i'm not hot-rodding my truck. No way, no how." F***'em if they can't take a joke.
Make them prove it.
Larry
1980 Jeep CJ7
Old 12-20-2004, 02:58 PM   #19
67ChevyRedneck
67ChevyRedneck's Avatar
Instead of getting another tranny, get your money back and invest in a 4L60 out of a new chevy truck. With a bowtie TV cable kit and a lock up kit you'll have OD. ALSO, the 700R4 and 4L60 have lower 1st and 2nd gear ratios than the turbo 350....not sure about the 400 though...The lower take-off gears will help with your hauling....also, do you have a 3.08 rear or a 3.73....a 3.08 may have contributed to your tranny frying. I personally think a 3.08 is too high for towing, even with a 350 tranny.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-20-2004, 02:59 PM   #20
71chevylongbed
Got Horsepower?
[QUOTE=spencra] "Ah, no sir, i'm not hot-rodding my truck. No way, no how."
Make them prove it.[/QUOTE
thats what i told him when he asked me. the he said that if i had he would be able to tell when he takes it apart and then if he tries to get me to pay for it im gonna tell him he can shove it up his a$$ and keep it!!!!
Old 12-20-2004, 03:03 PM   #21
71chevylongbed
Got Horsepower?
it has 3.73 gears
Old 12-21-2004, 01:48 PM   #22
71chevylongbed
Got Horsepower?
i talked to the guy down at the tranny shop and he thinks that it may have blown up the sprag. im no tranny expert so can some one tell me what the sprag does and how i could have blown it up.
Old 12-21-2004, 04:24 PM   #23
jmanz69
jmanz69's Avatar
The sprag is part of the planetary set in the trans. It is what makes it go. It is very possible that you blew it up. They are the weak part of a TH350. When you have one built for racing, they replace the stock type with a new stronger one. This isn't a cheap thing to have done, but they will last. Usually get no warranty on race transmissions. Otherwise, people would blow them all the time and have a new one at no cost. I would find a TH400 and go that way. 500 ft/lbs is too much for a TH350 to take very much of, especially if you were beating on it. Towing is one thing, racing is something completely different. Could also get a Tremec TKO 5-speed to go in there. Those are good to 500-600 ft/lbs. They are made for racing. Then you would have a stick as well.
Old 12-21-2004, 06:45 PM   #24
71chevylongbed
Got Horsepower?
i was wanting to put a muncie 4 speed in it when i fried the first tranny but i needed the truck fixed quick so i had the th350 rebuilt. i think that im just going to rebuild it again and then sell my truck
Old 12-21-2004, 06:57 PM   #25
arkracing
Weekend Warrior
i've had/seen a lot of trucks with stock TH350s that have pulled trailers and have been beat on and usually don't have any problems with them...even towing from RI to Fl - 1800 miles or so???
the only thing about a TH400 is it takes about 15 horsepower more to turn than a Th350. and they are bigger...don't fit in '33 ford Pickups very well
i really can see how a properly built TH350 can't handle that kind of torque...i'm sure that truck doesn't hook up all that well..like it said .."yeh it will smoke the tires"
and the dyno numbers seem kind odd to me...low horspower with that high of a torque number...i'm not sure how a chassis dyno compares to a regular engine dyno..but i thought HP was some mathmatical equation and torque was part of it.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
