Old 12-18-2004, 04:45 PM   #1
70c10
67-72 Addict!
70c10's Avatar
Brake squeel question
My brakes sound like fingernails on a chalk board!. It used to only do that when I really stomped on them but now it's constantly. I have power drum brakes and recently pulled all 4 wheels to look at the shoes and clean all parts real good . They all look good!. My master cylinder leaks a little out of the top. What would cause this annoying sound?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-18-2004, 10:01 PM   #2
tom hand
CCRider
tom hand's Avatar
Number one..are your shoes riveted or bonded...ie glued...if your shoes are bonded..change them...you will never stop the squeel
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 12-19-2004, 12:54 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Tom, I honestly can't remember. I think they might be bonded. They never used to make this sound all the time like now.
Jim
Old 12-19-2004, 02:39 PM   #4
68LSS1
68LSS1's Avatar
Could be just that the rotors are glazed. You can put a sanding disc (the 3M Scotchbrite work best, but a sanding disc around 120 grit will work) on a 90 degree and hit the rotors. Some backing plates make it impossible to do the back of the rotor without taking of the caliper but it can be done on the spindle.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 12-19-2004, 03:03 PM   #5
70c10
67-72 Addict!
70c10's Avatar
My truck has power drums. I cleaned the drums and everything else real good.
Jim
Old 12-19-2004, 09:05 PM   #6
68LSS1
68LSS1's Avatar
Sorry, I missed that. But the same still applies about the glazing. You have to use a abrasive or have them turned to get the glazing off. Good luck figuring it out.
'68 Short Step
Old 12-20-2004, 08:24 AM   #7
70c10
67-72 Addict!
70c10's Avatar
The drums looked good. I really need to bite the bullet and upgrade to a disc kit but can't justify the cost right now.
Jim
Old 12-20-2004, 09:18 AM   #8
Blue Beard
Blue Beard's Avatar
I've had some that did that, shaped the edge of the brake pads near 45 degrees and they stopped.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 12-21-2004, 03:01 AM   #9
Duner97
Duner97's Avatar
If everything looked ok when you had em apart, I agree with a couple of the others, could be glazed. You can sand em down, as mentioned, Or do what i do with the forklifts i work on and just ride the brakes like crazy til it stops squealing
72 SB 4x4
-Duner97
Duner97 is offline   Reply With Quote
