Old 07-05-2002, 07:11 PM   #1
Low69CST
Better pics of my Rear Camaro Bar Installed
Pic
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-05-2002, 07:12 PM   #2
Low69CST
pic
Old 07-05-2002, 07:21 PM   #3
Low69CST
pic
Old 07-05-2002, 08:23 PM   #4
Johngear67
The Mighty Blue Bottle
Wink
:p cool, but the exhuast looks even better
have fun:p
1967 Chevy C 10 Custom
350 780 cfm 467 lift 278 dur
ported&pollished
2400 stall 350TH
B&M shifter
175 shot of nitrious
Johngear67 is offline   Reply With Quote
Old 07-06-2002, 09:32 AM   #5
Cheyenne Super
sway bar location
I have a question for you. If you had coil-overs that mounted to the rear of the trailing arm, could you flip the sway bar so the arms of the sway bar extend forward?
Another question if space was tight due to existing exhaust, could you mount the sway bar to the frame and bolt the endlinks to the control arm or axle?
1971 Cheyenne Super
Soon to be converted to '68 front clip.
Efland, NC
Cheyenne Super is offline   Reply With Quote
Old 07-06-2002, 06:27 PM   #6
Low69CST
I'm not sure if you could turn the bar around or not. I remember that when I was first putting the bar on the truck, the "hump" in the bar limited alot of my first choices about how to mount the bar. I probably tried to turn it the way you were talking about. I can't remember if it was the springs or the differential center section that the bar was hitting.
If you were going to mount a bar to the frame I would get a straight bar. You could buy an addco bar, or you could get a "stock car" style bar from Speedway Engineering. If you have a gas tank back there, I can tell you that the only bar you'd be able to fit would be one of those stock car style bars. Those are just a bar with splined ends and you can push on the arms that extend out for the endlinks. This gives allows you to customize the arm length to what you need. If you mounted this camaro bar to the frame, you'd have a big hump in it that would be in the way all the time.
