Old 12-25-2004, 04:42 PM   #1
Kurt L
Kurt L's Avatar
taller coil springs
there was an article about a month or so about lifting two wheel drives.
the person that had the article was lifting a 73 or 80 model truck.i don't remember the person that had the article. but i would like to know the name of the company that sells those 2inch lift coils because i'm planning on lifting my 91. so any info would be greatly appreicated.
Kurt L is offline   Reply With Quote
Old 12-25-2004, 04:51 PM   #2
magnethead
7000 #'s of american IRON
magnethead's Avatar
if you get taller springs, you're also going to need taller shocks, otherwise you might max out the current ones by making the suspension seem 2" more extended. Get a shock 1 step bigger
magnethead is offline   Reply With Quote
Old 12-25-2004, 05:25 PM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
http://www.fabtechmotorsports.com/
They are expensive but they have lift kits for two drives
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 12-25-2004, 08:34 PM   #4
Prerunner1982
Prerunner1982's Avatar
lift coils will also cause tierod/ball joint and tires to wear. It puts the tierods and ball joints to be at excessive angles. But as of right now, that is about the only way to lift a pre 88 truck.. The tubular control arms maybe designed to correct the tierod/balljoint angle, cheaper ones may not. As of right now i have not found anyone that makes a lift spindle for pre 88s. AIM use to, but no longer and not sure i would trust it.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 12-25-2004, 09:49 PM   #5
magnethead
magnethead's Avatar
theres also this saying:
"if you want it done right, you have to do it yourself"
Old 12-25-2004, 10:18 PM   #6
Prerunner1982
also you will loose almost all of the droop tothe front suspension..
Old 12-26-2004, 05:20 PM   #7
88Jimmy4x4
88Jimmy4x4's Avatar
Are you talking about a 91 blazer or burb?
If so you want this kit
http://rough.roughcountry.com/RC%20W...hevyselect.htm
If your talking about a 91 truck you want this one.
http://rough.roughcountry.com/RC%20W...98Chevy2wd.htm
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 12-26-2004, 06:32 PM   #8
Kurt L
Kurt L's Avatar
i'm talking about 91 c1500 pickup,short wheel base.thanks for the help and info.
checked out the site and found just what i need.thanks again.
