Old 01-01-2005, 10:58 AM   #1
nite53
SBC Mounts????? HELP PLEASE
Hi everybody,
I just bought a 67 that was supposed to have had a SBC in it before the engine got removed, but after talking to the guy that owned the truck before the guy I bought it from, it was a 6 cylinder!!!!! I'm trying to get some info about this before I jump in the engine compartment, and to get parts ready before starting with this. What will I need to put the V-8 into a 6 compartment for mounts? If anybody has what I need, PLEASE PM me!
Looking at this truck now, makes me realize that I bought a parts truck and I want to revive it, so please help!!!!!!!!!!! Thanks in advance.
Nite
nite53 is offline   Reply With Quote
Old 01-01-2005, 11:31 AM   #2
purple gas
Relax man... take a deep breath,, have a cup of decafe.. You'll need a couple V-8 motor mounts.. I've seen v-8's mounted on 6 mounts, but you want to do it right..Someone will have the mounts, you'll give 'em a few bucks, and your troubles will be over..( well your motor mount troubles,, there will be other troubles, but that's just life). It's a new year,, it's a new day...Think posative.. we're here to help...
purple gas is offline   Reply With Quote
Old 01-01-2005, 05:53 PM   #3
crazy longhorn
Fabricate till you "puke"
You can do that job a few different ways.....personally, i like the sb dropped in I 6 position, there are pros & cons both ways. my 1st ? , is what are you running for trans? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-01-2005, 08:07 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Put it in on the 6 cylinder mounts. That way you don't have to jack with the transmission, crossmember moving, driveshaft lengthening, linkage modification and all of that.
If you put it in on the 6 stands, all of that stuff gets left alone. It's much faster, easier, and cheaper.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-01-2005, 08:36 PM   #5
crazy longhorn
/\....what he said! auto trans, no issues....if you are runnin a stick, tell us....I know what works, as I am sure a bunch of guys do crazyL
Old 01-02-2005, 05:56 AM   #6
nite53
Thanks!!!!
Hey Guys, Thanks for that info. I'm going with a short TH 350 so everythings cool!!!!!! Do ya know if the driveshaft will accept that tranny without changing yokes?
Thanks Again,
Nite
Old 01-02-2005, 08:54 AM   #7
Tx Firefighter
It depends on what type of transmission the yoke is intended for.
If it was a manual 3 speed, yes it will work with the TH350.
If it was a TH400, no it won't work.
Old 01-02-2005, 09:43 AM   #8
modifiedGMC
I got a 350 V8 on 6 cyl. mounts and it all works fine. no problems.
modifiedGMC is offline   Reply With Quote
Old 01-02-2005, 10:01 AM   #9
nite53
Drive shaft yoke
The driveshaft I have is a two piece, "supposed" to be the original. If I remember right, the column shift is set up for automatic, a 3 spd. if I remember right. Would/could it have had a 400 in 67?
The ONLY nomenclature tag I can find on this truck is the serial plate on the door post. That tag lists the VIN number, and below that is "DD". Any ideas what that stands for? Where else (besides the glove box since it's weather destroyed) can I find build info? Was there a tag on the firewall? I built a 67 Malibu years ago, but I've forgotten so much.................. too many birthdays I guess!
I have this truck in a storage lot right now, I'll have to go look to see if the yoke will go into the 350 tail.
Thanks Again
MY TOYS:
1964 XLH Sportster
1973 HD Sportster
1974 HD Sportster
1987 HD FXR Super Glide
2004 HD Sportster
1989 Chevy Dually, 1992 Chevy Van,1991 Pontiac Sunbird Conv, 1967 Chevy PU, 1977 Chevy Van, 1963 Chevy Nova,1963 Chevy Nova SS,
1953 Chevy Panel Van
