Old 01-03-2005, 08:54 PM   #1
tmad
Aluminum Intake ?
What do you guyd do to keep your aluminum intakes looking good over time? Any tricks your willing to share?
tmad is offline   Reply With Quote
Old 01-03-2005, 08:57 PM   #2
724wdcopper
graphic designer
724wdcopper's Avatar
carb cleaner and a pressure washer, works for me. of course you know to cover the carb and protect the distributor.
724wdcopper is offline   Reply With Quote
Old 01-03-2005, 09:17 PM   #3
tmad
Neat idea! Have you ever clear coated one?
Old 01-03-2005, 09:48 PM   #4
cochran63
cochran63's Avatar
I am having my intake powdercoated with a clear color. I hope it will keep the intake from looking dull over time.
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 01-04-2005, 12:06 AM   #5
4x4Poet
I'd be curious to know whether the clear powdercoat will stay clear amidst the engine heat. Let us know in a year or so.
Had I an alum intake, I probably would try using Durashine.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 01-04-2005, 12:33 AM   #6
incoma
incoma's Avatar
I just used clear enamel spray paint after I bead blasted it. It works good for a year or two. I generally took my engines apart to build a new one after a year or so anyway so the time the paint lasted didn't matter to me much.
incoma is offline   Reply With Quote
Old 01-04-2005, 08:39 AM   #7
tmad
What is Durashine???
Old 01-05-2005, 04:56 AM   #8
4x4Poet
Durashine. The mfr url Durashine.com doesn't work for this dialup user. No matter. I've found Durashine at kmart, walmart, etc.
I wonder if POR15 engine enamel in aluminum would work. I suppose it would only be appropriate if you wanted to cover some unremoveable stain in the cast pits of the alum intake. Bare cast alum with no flaws is better if it's left unpainted (with pigments, that is).
I wonder if POR15's Metal Mask would work. It is UV resistent. It's not a high heat paint, but it must be rated to 500ยบ like POR15 is. Maybe too little heat protection to be incontact with water/exhaust passages. It could and should be brushed on, preferably with a foam brush. Just wondering.
Old 01-05-2005, 08:44 AM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Let me look, I have a picture of a clear powdercoated intake that's been run several years. I'll find and post it. It looks pretty good still.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-05-2005, 08:48 AM   #10
Tx Firefighter
Picture is blurry.
Was powdercoated about 10 years ago give or take, the new owner has not cleaned it that I can tell. It would look better if he'd clean it every once in a while.
Old 01-05-2005, 09:14 AM   #11
arkracing
Weekend Warrior
I just spray them with regular clear from the paint store - usually when i'm clearing a car or something.
POR also makes a clear finish that supposedly can be put on chrome and shiny stuff...wonder if that would work.
if i don't feel like clearing them i usually just paint them the same color as the motor.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 01-05-2005, 09:23 AM   #12
GMC AMI
GMC AMI's Avatar
Black will dissipate the heat quicker! When into drag racing we almost always painted them black.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 01-05-2005, 10:29 AM   #13
superchevy
Got big-block?
superchevy's Avatar
powdercoat it.
I've run several powdercoated intakes...not clear, but aluminum finish or "almost chrome" they call it...with no discoloration whatsoever. Then again, I powdercoat everything...I hate cleaning polished aluminum, and powdercoating makes it so easy to clean.
SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 01-06-2005, 06:23 AM   #14
tmad
Well I went with the High heat (1200f ) Then baked it for a few hours,it sure looks good now Ill let ya know in the spring how it holds up!!!! Thanks for all the input I think I will powdercoat the next one. Todd
