Old 01-04-2005, 04:54 PM   #1
low 84
low 84's Avatar
4wd front rebuild kits
who sells a good front end kit for 4wd's. i want to replace everything, all tierods, all ball joints, pitman arm, ect.
i was looking at the ones at www.performancesuspension.com they have a kit for 73-80 with everything for $360 but their kit for 81-87 is $280, what is the difference in the 4wd front ends between the 73-80 and 81-87's?
thanks
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 01-04-2005, 05:26 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I can't answer your question, but I can say that I was happy with the service they provided when I ordered my drop spindles and springs.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-04-2005, 05:28 PM   #3
grape
grape's Avatar
dana 44 and 10 bolt I guess.
grape is offline   Reply With Quote
Old 01-04-2005, 05:29 PM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
73-80 should be a Dana 44, 81-87 is a 10 bolt. Both rears are close but slight differences...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 01-04-2005, 06:20 PM   #5
low 84
low 84's Avatar
i'm pretty sure the front is a 10 bolt. why would having a d44 make the front end kit $80 more?
'05 1500 Crew Cab
RIP
Old 01-04-2005, 06:27 PM   #6
1972
Majician
1972's Avatar
The only price difference I could think of would be for pre-76 dana 44's with the flat top passenger side knuckle, because the tie rod end (the long one) is about $90 more than one for a 76+ D44 and the 10 bolt. 10 bolts were used in '79, so I don't know what the 80/81 split price difference could be for.
1972 is offline   Reply With Quote
Old 01-04-2005, 08:31 PM   #7
784X4GUY
Did someone say MUD?
784X4GUY's Avatar
That is one thing I still have to do is rebuild my dana 44...Later Mike
Im in the market guys...so keep ya eyes peeled
Mini trucks are for guys who cant get it up!
784X4GUY is offline   Reply With Quote
Old 01-05-2005, 01:47 PM   #8
low 84
low 84's Avatar
ttt, nobody has rebuilt to front end of a 4wd?
'05 1500 Crew Cab
RIP
Old 01-05-2005, 02:27 PM   #9
1972
Majician
1972's Avatar
I rebuilt mine. I also put in new u-joints, bearings, races, and seals. I bought all of my parts locally, some from the 4x4 shop and some from Napa and AutoZone.
Old 01-05-2005, 06:59 PM   #10
1987SierraClassic
I got most of my stuff from Parts Mike. Good prices on genuine McQuarry-Norris (Dana Spicer) stuff. I bought new brake rotors and axle shafts from Coleman's Surplus (www.colemans.com). The brake rotors were OEM with the wheel bearings for $50 and the axleshafts were new OEM for $40 each.
Parts Mike is also very knowledgable and more than willing to share it even if you don't buy anything!
http://www.partsmikeparts.com/
1987SierraClassic is offline   Reply With Quote
Old 01-05-2005, 07:05 PM   #11
white82
White 82
white82's Avatar
not to but in on this thread but i have a 82 4x4 and i think my 3rd member is shot on the front would that be a 10 bolt8.5 if i wanted a posi?
1966 GTO 455 e-heads, 1982 Chevy k10 4'' lift 33’' tires, 2008 Pontiac g6 v6
white82 is offline   Reply With Quote
Old 01-05-2005, 08:48 PM   #12
1FaastC10
1FaastC10's Avatar
talk to Tim, i'm pretty sure he's done one of his at one time or another. he can get ya the hookup on ANYTHING you need for your truck too.
1FaastC10 is offline   Reply With Quote
Old 01-05-2005, 08:55 PM   #13
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
I completely went through the 10 bolt on the front of my 84. I used all McQuay norris or Sealed power parts that I bought locally. I haven't seen a rebuild kit for a 4x4 front end.
I replaced all 4 ball joints, both drag link ends and adjusting sleeve, both tie rod ends and center bar, wheel bearings, front axle u-joints, calipers, brake pads, and rotors and the sway bar bushings.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 01-05-2005, 09:50 PM   #14
Ecnerwal
Make sure etc. includes the U-joints. Prepare your wallet for the possibility that the selector hubs may be shot - that adds a pretty penny.
Shot front-wheel U-joints can cause problems that feel like screwed up tie-rod-ends, but persist when you've replaced all the tie rod ends.
Cats, Coffee, Chocolate...vices to live by.
1987 Custom Deluxe 30 4wd crew cab
134000 miles and counting.
Ecnerwal is offline   Reply With Quote
Old 01-06-2005, 03:48 AM   #15
1972
Majician
1972's Avatar
I am not sure about anyone else, but I always use Spicer greasable u-joints in my axle shafts. The axle shaft joints are the smallest u-joints on the truck and usually the most stressed.
