Old 01-09-2005, 01:41 AM   #1
SoldierFixer
Nose-high Blazer ride height disease
OK so my '70 has a 6/5.5" Superlift kit (springs F&R) and sits kinda silly... most lifted Blazers I've seen sit with a nose high attitude (I'm guessing because the lift manufacturers spec their springs for pickups, which sit tail-high from the factory). Who has corrected this and leveled their K5? How did you do it? Would you do it that way again? I'm thinking a Superlift 1.5"-2" Add-A-Leaf would work, but if anybody else has an idea....
Thanks,
Adam
SoldierFixer is offline   Reply With Quote
Old 01-09-2005, 04:56 AM   #2
earl87gta
earl87gta's Avatar
I use ord 0rate springs.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 01-09-2005, 11:01 AM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
WELCOME 2 THE BOARD FROM WEST 10-UH-C
Mine Has A 4/6 Lift, Supposed To Be Level With The Top On
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-09-2005, 11:55 AM   #4
Scrubby
Check out GMTrucks.org
I also used ORD 0 rates to fix the problem. They are just lilttle 1 inch blocks really that help level it out.
My lift is a 4 inch tuff country from suspension connection. They automatically send you 4 inch springs for the front and 6 inch for the rear when you order for a 69-72 blazer.
Scrubby is offline   Reply With Quote
Old 01-09-2005, 02:23 PM   #5
Has anyone noticed how bad Blazers handle nose-down??I`m asking because I`ve found nose-up gives better handling on the roads,especially rough ones.It feels like the rear just follows the front better.Kinda like a motor boat.It takes weight off the front steering which takes alot of pitch`n`roll out of the handling.Trucks,too.This has been my experience at least.I bought a`90 K/5 new and I noticed it sat nose-down.It was my wife`s family-driver and I wasn`t planning on lifting it.I took it to the spring shop and had it brought it up about 2".This made it level to maybe 1" up.What a difference in handling.Seems alot of lift kits on PUs leave a nose-up stance too.
Old 01-09-2005, 10:50 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
SAME KIT, AND IT RIDES SUPRISINGLY DAMN GOOD
Old 01-10-2005, 02:32 PM   #7
71jimmy
71jimmy's Avatar
LUV2XCLR8 - FYI, your bio on GQ says Rough Country springs. I've seen you post you had TUFF Country springs before. I know you know these are different and its a toungue twister bt TUFF and Rough. No big deal, don't mean to trash just a friendly note.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 01-10-2005, 04:32 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
YOUR RIGHT, I'M STUPID, OH WELL, MY KIT WAS A 4/6, DUHHHH
Old 01-10-2005, 05:47 PM   #9
vtblazer
vtblazer's Avatar
I have an all spring 4" lift on my blazer with no butt hang at all.
4" in front, 4" in the rear, seams to sit pretty level.
It's one of those "EZ Ride" kits. Although they sent me the wrong shocks with it.
vtblazer is offline   Reply With Quote
Old 01-13-2005, 02:41 AM   #10
K5KRAZIE
Talking
For the leveling I have 4" front springs with 6" rear springs. I removed the overload leaf from the rears though.....
TRUCKS
'72 K5
'06 mega dually
K5KRAZIE is offline   Reply With Quote
Old 01-13-2005, 12:28 PM   #11
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
My '72 rides high in front. It has 4" front springs with rear blocks and helper springs. Leveling it out isn't high on my priority list though. My '69 rides level with 6" front springs and 6" rear blocks. If I were going to keep the '69, I'd probably want to swap in some rear springs with zero rates.
Aaron, you've done some trimming to your front fenders so you don't have rub issues, right?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 01-13-2005, 03:25 PM   #12
K5KRAZIE
I did trim the front of the rear fenders a long time ago. I have since moved the axles to compensate.
TRUCKS
'72 K5
'06 mega dually
