Old 01-10-2005, 06:12 PM   #1
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Question HELP - REMOVING T HANDLE & HATCH
GOT THE GLASS OUT, GOT THE T-HANDLE HARDWARE OUT, NOW HOW
DO YOU GET THE HANDLE OUT, AND HOW DO YOU REMOVE THE HATCH
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-10-2005, 06:15 PM   #2
vtblazer
vtblazer's Avatar
[QUOTE= HOW DO YOU REMOVE THE HATCH[/QUOTE]
You mean from the top itself?
There's two sets of 3 bolts under a small metal cover on the under side/rear of the top.
vtblazer is offline   Reply With Quote
Old 01-10-2005, 06:24 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
SAME THING TO REMOVE THEM FROM THE HATCH
AND WHAT ABOUT THE DAMN T-HANDLE
Old 01-10-2005, 06:35 PM   #4
vtblazer
vtblazer's Avatar
Yep.
T-handle: Doesn't it just have two screws from the outside holding it on?
Old 01-10-2005, 06:37 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Yep.
YES, BUT IT WON'T GO THROUGH THE HOLE, AREA THAT RODS ATTACH
TO IS LARGER THAN THE OUTER HOLE, I THINK IT'S 2 PEICE, NO IDEA
Old 01-10-2005, 07:14 PM   #6
cheyenne10
cheyenne10's Avatar
square shaft
If I remeber right my stock one removed very easily. The square shaft is the only thing really sticking towards interior. The thing it runs through I think stays in door. Maybe post a picture to jog our memory.
Bob
cheyenne10 is offline   Reply With Quote
Old 01-10-2005, 07:20 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I already removed internal bracket, that might be the problem
Old 01-10-2005, 08:58 PM   #8
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Reomove the hatch hinge access covers 1st.
Remove the 3 bolts on each side,either the top side or the hatch side,whatever you prefer.
reomove the screws you can see on the outside of the T-handle.
Take off T-handle access cover and check the internals for clips or pin's that may be preventing removale of the handle.
I have cotter pin's in mine which need to be removed before the T-handle will come out.
I also added cotter pins to the rods that go out to the latches at the side.This prevents them from accidently becoming disconnected from the T-handle assembly inableing me to open the hatch.
Then of course remove the suppot arms and lift that heavy hatch off the top!
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 01-10-2005, 09:11 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
THANKS
PIC #4 IS MY PROBLEM, MINE WAS MISSING THAT SPLIT RING
Old 01-10-2005, 09:35 PM   #10
BobbyK
BobbyK's Avatar
without that spring clip the sleeve the T-handle slides into will come out.
If that happens the springs will unload.
Old 01-10-2005, 10:00 PM   #11
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
YUP, I CAN FIX THE UNLOADED SPRING, WILL TRY AGAIN TOMORROW
Old 01-11-2005, 12:22 PM   #12
Steven B
Steven B's Avatar
I have the same problem but the T-handle is rusted to the spring. How do you remove it?
Steven B is offline   Reply With Quote
Old 01-11-2005, 03:10 PM   #13
BobbyK
BobbyK's Avatar
soak it with WD40 or some other kind of penatrating oil.Give it a few taps with the handle of a screw driver while trying to pull it out.
If it's REALLY rusted it may take a few applications of WD40 to get it loose.
I wouldn't recommend prying on it as you may bust something!
Old 01-11-2005, 04:29 PM   #14
vtblazer
vtblazer's Avatar
Hey, this has turned into an FAQ thread.
Steven B, some sort of penetrating spray should work.
PB blaster always works really good for me.
Any luck yet LUV?
Old 01-11-2005, 05:44 PM   #15
pound41
If the Handle is really seized and won't come free. I have removed several from the yards by lightly sanding the shaft Then take a small c- clamp and put one end on the shaft and the other one the inner bracket, No real stress on the fiberglass. Iwill break it free without bangin
pound41 is offline   Reply With Quote
