01-12-2005, 05:32 PM | #1 |
Right turn Clyde
Pypes exhaust system
I have an exhaust video if anyone wants to see it. I would like to try and get it hosted somewhere but its a 6.21mb file. I have it converted to wma file format and that got the file a little smaller from the 8mb file it was. I could cut off the last couple of seconds. But I haven't found a program to do that yet. I thought XP was supposed to have a program to do that type of stuff but I haven't found it or anything what will in XP yet.
I cant in my case say anything to good about the fitment. I also wasn't able to use the crossover pipe. That may be my fault thinking I could just put it together and weld it up and everything turn out excellent. I didn't have any such luck. I took my time thought about the things I did and cut some parts to fit. I do like the fact that the pipes are mandrel bent and the mufflers though. I would be a lot happier if everything went like I thought it would have and use the whole system. The system isn't made for are year trucks, its a universal system. That's were some fabrication comes in play more so than it would with an exhaust system that was fitted vs universal. So anyone want to hear it?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
01-12-2005, 05:42 PM | #2 |
www.73-87chevytrucks.com
Sent it to me and I will host it for you.
The system actually is made for 73-87 trucks. They designed it on a 73-87 LWB truck. It would have to be cut for a SWB. Not sure why you weren't able to get it to work for you. Swervin had his pretty easy.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
01-12-2005, 05:45 PM | #3 |
Right turn Clyde
Okay via email?
I pm'ed you just to make sure.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI Last edited by MylilBowTie; 01-12-2005 at 06:10 PM. |
01-12-2005, 06:12 PM | #4 |
I've been looking at the Pypes system. Woud like to hear it and see some pics!
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
01-12-2005, 08:52 PM | #5 |
01-13-2005, 10:46 AM | #6 |
Right turn Clyde
01-13-2005, 12:23 PM | #7 |
Capt:
Does the Pypes system with crossover fit the 4x4's?? - Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
01-13-2005, 05:15 PM | #8 |
The issue with the 4x4's is you would have to build a drop pipe so one leg would go under the transfercase.
