Old 01-12-2005, 11:43 PM   #1
walkintall49
What Ratio?
What is the laymens way to tell what gear ratio I have in my 72?
walkintall49 is offline   Reply With Quote
Old 01-12-2005, 11:50 PM   #2
Peregrine
Peregrine's Avatar
take the cover off and count the gears on ring and pinon. Divide large number by small number and there ya go.
Brian
72 C10 longbed 350/th400
Let the world change you and you will change the world.
Peregrine is offline   Reply With Quote
Old 01-13-2005, 12:14 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yup, and you get to drain the 33 year old oil, and check for metal chunks floating around too.
Old 01-13-2005, 12:47 AM   #4
jhow66
jhow66's Avatar
How about the "lazymans" way-jack up one rear wheel -put trans in netural-make a mark on drive shaft-make a mark on tire-turn tire 2 times while counting the # of times the drive shaft turns--little over 3 times= 3.08, about 3 3/4 times = 3.73 and so forth.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-13-2005, 12:56 AM   #5
Peregrine
Peregrine's Avatar
ooo, I like that way
Brian
Old 01-13-2005, 01:39 AM   #6
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
That way don't small as bad either
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 01-13-2005, 06:31 AM   #7
Longhorn Man
yeah, but then you still have old oil that isn't doing it's job.
3.08 wasn't used in these trucks, it's a 3.07
Old 01-13-2005, 12:22 PM   #8
jhow66
jhow66's Avatar
Right 3.08 was cars-my bad.
Old 01-13-2005, 07:49 PM   #9
Blazer1970
Blazer1970's Avatar
If it is a half ton that came with a 350, it came with 3.07s. If it came with a 307 or a 6 cylinder, it came with 3.73s. Any other ratio was optional and would be listed on the glove box sticker.
Blazer1970 is offline   Reply With Quote
