Old 07-09-2002, 07:27 PM   #26
Yellow Cheyenne
Don't be afraid of the project or the spring pressure, but have a healthy respect for the spring power. A jack under the lower a-frame as descibed above works and is how I've done it in the past. For a safety measure, you can either put small chain around the spring and some other part of the frame or run a rod through the middle of the spring so that if something does go wrong, you don't have a loose spring trying to take your head/hands off. Good luck
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72)
'56 Chevy short step V-8 (My dad bought it new!!)
'70 Olds 442 convertible
'70 Olds Rallye 350
Yellow Cheyenne is offline   Reply With Quote
Old 07-09-2002, 07:43 PM   #27
Paul Clark
Hey 71402BB -
Got a mechanic friend who swears by brake cleaner. It cuts through anything and doesn't leave any residue. He's got a metal spray can that he can pressurize. Buys the stuff by the gallon and sprays away. It will also tell you if you have any cuts on your hands.
Found another "pretty good" cleaner. Windex (or generic equivilant) and a couple cap fulls of acetone. Seems to work pretty good.
Paul Clark is offline   Reply With Quote
Old 07-09-2002, 08:45 PM   #28
1968 C-10Cowboy
Once again...All of everyone's imput is greatly appreciated. As far as the disc brakes.....already been accomplished by the first owner. I will invest in the "Brake Clean" stuff too!
Thanks again.
"Longhornmail.......You will be my first to call if i goof up somethin....:p
350/.30 400 Turbo Trans 3.73 Rear end
1968 C-10Cowboy is offline   Reply With Quote
