Old 07-10-2002, 10:53 AM   #1
soupcan
Question Electrical plugs on firewall...
Hello All--
I'm trying to track down a short in the electrical system of my '72 truck. I was looking at what appear to be plugs where the wires go through the firewall near the power brake booster. I tugged on them a little but they didn't budge. Are these really plugs? Do they unplug from outside or inside the cab or both?? I've heard that you guys replace entire cabs, so I assume that something must disconnect somewhere!!
Thanks in advance...
soupcan is offline   Reply With Quote
Old 07-10-2002, 11:01 AM   #2
Randy70C-10
Randy70C-10's Avatar
That square thing that the wires go through IS a plug. If you take the center bolt out, the plug will come out.
Randy70C-10 is offline   Reply With Quote
Old 07-10-2002, 12:15 PM   #3
Low69CST
I think your talking about the tail light plugs. I can't remember if they come out from the inside or outside. There are a couple other cables that run out of the cab around there, make sure its not one of those.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-10-2002, 01:00 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Witch wires are you talking about? The main harnesses that behind the fuse panel? If so you have to unscrew the 3/8" screw that holds the two plugs in. Then you can seperate the two by sliding them apart. The other harness that is close to the firewall is the taillight harness and the part that unplugs is actually on the interior side of the firewall. You can unplug it from the engine side but molded to the harness itself is the grommet that protects the harness. You can work that grommet out by wiggling it around and it will come out. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 07-10-2002, 02:06 PM   #5
soupcan
Thanks! It is the main harness behind the fusebox, and now that I've peeled back the crust and wires, I see the screw holding me up! Thanks!
