Old 01-17-2005, 08:12 PM   #1
rockguy
Alternative to Dynamat or brown bread
By accident I ran across this stuff at Lowes its called Peel and seal self stick alum roll roofing it comes in a 100 sq. ft roll for 79.99 36" by 33' long according to the box it comes in smaller widths. I used this weekend to do my 87 dually. works great easy to use. I didnt even use a heat gun but its pretty warm here you might have to use the heat in colder climates. I dont think I used even 1/2 the roll I may do a second layer. Just thought I would pass it along.
Steve
69 c-30 dually flat bed & dump ( best truck ive owned
87 chevy dually
97 1500 classic
89 wellcraft
rockguy is offline   Reply With Quote
Old 01-17-2005, 08:44 PM   #2
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Thanks for the tip. Will check it out on the next trip.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 01-17-2005, 08:52 PM   #3
junkyardjohn
junkyardjohn's Avatar
COOOOOL ... I'LL CHECK EM OUT. THANKS JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-18-2005, 01:33 AM   #4
muddpile
muddpile's Avatar
I've heard of it before. From what I've heard it works fine on a horizontal surface, but I wouldn't use it on vertical. Just a couple tips I've heard. I use Brown Bread Myself.
muddpile is offline   Reply With Quote
Old 01-18-2005, 08:57 AM   #5
rockguy
I used it on the back wall of my cab and its there forever. I thought of using it on the roof I know it will stick alright but I dont know if it will affect the headliner. plus its a lot cheaper than the others.
87 chevy dually
97 1500 classic
89 wellcraft
Old 01-18-2005, 09:45 AM   #6
Curbstone Mech
Active Member
Appreciate you passing on the tip.Its one of the best things about this board.
I'm going to try it in a daily driver type 4x4 we just started working on. Brown bread and Dynamat are pricey, especially when you're working on more than one truck. I like to find things that give a good benefit without spending a fortune.Thanks for sharing your "find" Rocky
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
Old 01-18-2005, 11:18 AM   #7
mt Al
Thanks, Rockguy.
I put some brown bread in a suburban. It worked well and cost a bundle! Can't wait to put some in my truck.
'72 GMC 1/2T 4x4 1500 Super Custom pickup (current)
past rides were:
'70 Chev 2wd farm truck
'71 GMC 2wd 1/2T 402 nice!
'72 Chev 2wd 1/2T 396
'72 GMC 3/4T 4x4 2500 Super Custom suburban.
Bozeman, Montana
mt Al is offline   Reply With Quote
Old 01-18-2005, 11:34 AM   #8
'70_402
'70_402's Avatar
got some pics????
'70_402 is offline   Reply With Quote
Old 01-18-2005, 07:20 PM   #9
stea
Im using the same stuff (peel and seal) on my 39. I found it at a local roofing supply, 12" x 33'. I've done about 1/2 the cab. If you use some 3M 90 (i think) adhesive with it it should hold to the walls and ceiling very well. I had to remove a small spot and had to use a screwdriver to scrape it off.
stea is offline   Reply With Quote
Old 01-18-2005, 07:26 PM   #10
fishmunger
fishmunger's Avatar
i just did up the entire interior of my 81 c10 with fatmat. its exactly the same as dynamat. you get it off ebay in either 50 ft or 100 sq ft. it even comes with a dynamat example to compare and a roller. it was $130 for 100 sq feet. good stuff.
fishmunger is offline   Reply With Quote
Old 01-18-2005, 10:27 PM   #11
70c10
67-72 Addict!
70c10's Avatar
I just did this in my dads 70'. I bought this off ebay from this guy. Worked awesome!.
http://cgi.ebay.com/ebaymotors/ws/eB...=WDVW&tc=photo
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-18-2005, 10:53 PM   #12
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Anyone ever tried FAT Mat?
http://cgi.ebay.com/ebaymotors/ws/eB...category=42610
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
