Old 01-10-2005, 01:38 AM   #1
Piper71c10
Unending Project
Piper71c10's Avatar
WTB: Alt Bracket for Head w/o holes
Got a set of double hump heads w/o acc bolt holes, and looking for a alt bracket setup that would work with these. Anyone?
Piper
Piper71c10 is offline   Reply With Quote
Old 01-10-2005, 03:47 AM   #2
muddyole 69
alt set up
Any reputable rod shop should have the aftermarket stuff got mine thru Jegs Mail order a few years back and was around 50 to the door check with them online @ Jegs.com goodluck Mike
hav'n fun be'n me
muddyole 69 is offline   Reply With Quote
Old 01-10-2005, 05:21 AM   #3
MOTHERTRUCKERS
30.00 including shipping, they are cleaned up ready to paint off a 67 327 with lower block mount,spacer and top adjuster arm.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 01-10-2005, 12:48 PM   #4
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
the two i have had.......were the arm that went from the water pump to a header stud....and then the one off my dad's 86 goes from the water pump to the intake....why wont those work?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 01-10-2005, 09:15 PM   #5
MOTHERTRUCKERS
If you have a short water pump the 73 and newer brackets are for a long water pump 72 and eariler were short pumps.
Old 01-10-2005, 09:39 PM   #6
Piper71c10
Unending Project
Piper71c10's Avatar
MotherTruckers-
I'll take you up. PM me your address and I'll mail you a check.
Piper
Old 01-10-2005, 10:34 PM   #7
southern parts
southern parts's Avatar
does your truck have the right exhaust manifold for the early type alt brackets?
southern parts is offline   Reply With Quote
Old 01-10-2005, 11:21 PM   #8
67ChevyC10Stepside
oh....i never knew the difference.....was just trieing to help
Old 01-10-2005, 11:47 PM   #9
Piper71c10
Unending Project
Piper71c10's Avatar
What is the correct manifold for the alt brackets? This isn't for me, it's for a pal that put a cheap ass set of new heads onto a box van that he want's to dump. It's like an 82 gmc 1 ton, so I'm now not sure what will work.......
Piper
Old 01-11-2005, 02:28 AM   #10
MOTHERTRUCKERS
There is also early alt and generator brackets that bolt to the front of the driver side ramhorn exhaust and some later that bolt to the side. I also have these and the driver ramhorn if interested.
Old 01-11-2005, 08:33 PM   #11
MOTHERTRUCKERS
piper71c10 I sent you a pm almost all my alt and generator brackets are either stolen or the scrap guy got them by mistake, if you have sent the check i will try to get some more this week if not i'll still try to get them for you. I have lots of guys that owe me favors aroud here.
Old 01-16-2005, 04:14 PM   #12
Piper71c10
Unending Project
Piper71c10's Avatar
Revisiting this a little bit, Still looking for a bracket, but I want one to mount the Alt on the passenger side. Anything like that out there?
Piper
Trying to help a buddy out who is getting pretty desperate...
Old 01-18-2005, 11:14 AM   #13
Piper71c10
Unending Project
Piper71c10's Avatar
ttt
Old 01-18-2005, 11:53 AM   #14
Hotrodhenryj
Truck Farmer
Hotrodhenryj's Avatar
Brackets
Here is a pic of the brackets and also how they mount. You will need to have the exhaust manifold that matches this setup. 25 shipped. Chuck
Arizona rust free sheetmetal
Hotrodhenryj is offline   Reply With Quote
Old 01-18-2005, 03:33 PM   #15
67ChevyC10Stepside
change your water pump and use this style setup....
Old 01-18-2005, 03:35 PM   #16
67ChevyC10Stepside
i have an extra setup like this if this is what you want to do. water pumps are extremely cheap and i personally have like 6 extras lol so it wouldnt be hard to do.
Old 01-19-2005, 05:24 PM   #17
Piper71c10
Unending Project
Piper71c10's Avatar
67c10--- that doesn't bolt to the head anywhere?
if not, I'll take one, how much shipped to 98382?
piper
Old 01-19-2005, 09:59 PM   #18
67ChevyC10Stepside
look at the second pic up....bottom bracket bolts to the water pump bolts..the top one bolts to water pump and intake....hell i dont know what to charge for them lol
Old 01-19-2005, 10:39 PM   #19
Vince Putt
Hippy
The pictures posted the lower bolt goes through the bracket then alternator then through a spacer to a head bolt hole. Look under the alternator you'll see the spacer.
Vince Putt is offline   Reply With Quote
Old 01-19-2005, 10:41 PM   #20
67ChevyC10Stepside
awww chit you're right..that's the only head bolt the setup uses..
Old 01-20-2005, 12:23 AM   #21
Piper71c10
Unending Project
Piper71c10's Avatar
I see... anyone ever flip one like HoTRodHenryJ has to use on the passenger side?
I'm dead set on mounting this thing on the pass side, and would like to find one sooon!
Piper
