07-11-2002, 11:11 AM | #1 |
Maximum Rear Tire Width?
1970 Model C10 LWB Stock Suspension (Coil Springs)
How wide can I go on the back with out any rubbage? I would like to run Mickey Thompson E/T Street Tires 31 x 16.5...Suggested Rim Width 12"...Outside Diameter 31.0"...Tread Width 13.0" All feedback wellcomed. Thanks In Advance,
1970 Model C10 LWB, Small Block 421 CID, AFR 220 Heads, 1050 Dominator, Super Victor Intake, Comp Cams Mech Roller, Comp Cams ProMagnum Roller Rockers, 13.8:1 Compression, 4500 RPM TCI Converter, TH400 TCI Transmission w/reverse manual valve body w/trans brake, 5.13 Rear Gear on a full Spool, 31-16.50-15 Mickey Thompson ET Streets Last edited by sbc421; 07-11-2002 at 11:13 AM. |
07-11-2002, 07:27 PM | #2 |
You can go as big as 15x14" w/10" backspace & 31x18.5 MickeyThompson Sportsmans w/o changing the frame, suspension, or rear end width. I had this size on my restorod 67 short-wide & used custom widened ralleys. Of course it did require tubbing the bed to fit & the e-brake cables were hooked up but I never actually used the e-brake during the period the tires were on the truck so I can't say for sure whether they worked but the tires cleared & didn't rub the body or frame.
07-11-2002, 10:46 PM | #3 |
I have BFG Radial/ta. 295/50 R15 on a 15X8 Chvy Rally wheel No problem
07-12-2002, 12:29 PM | #4 |
Thanks for the info guys.
Jeff
1970 Model C10 LWB, Small Block 421 CID, AFR 220 Heads, 1050 Dominator, Super Victor Intake, Comp Cams Mech Roller, Comp Cams ProMagnum Roller Rockers, 13.8:1 Compression, 4500 RPM TCI Converter, TH400 TCI Transmission w/reverse manual valve body w/trans brake, 5.13 Rear Gear on a full Spool, 31-16.50-15 Mickey Thompson ET Streets |
07-12-2002, 09:06 PM | #5 |
Slowly getting CRSS...
i have 12'' cragars w/ 8'' bksp w/ 29x15.5x15 MT's to go w/ 18.5 i think you would have to remove the bumpstop hangars. heres the tubbed wells
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
07-12-2002, 11:08 PM | #6 |
Yes you will need to remove the bumpstops if you go that wide. I didn't think about that earlier because mine were already removed from when I lowered it.
07-15-2002, 11:35 PM | #7 |
Cowboy Fan for Life!!!!!!
That tub job looks great!! I have little bitty 295/50/15's compared to you guys. But it's not the size that co........ Who am I kidding, fat treads rock!!!!........JB
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
07-19-2002, 01:21 PM | #8 |
i love summertime
damn hvychevy454
i cant get over that orange...
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
