Old 01-21-2005, 01:00 AM   #1
Shev
Head Peon
Shev's Avatar
Slam Specialties RS-82's all the way around...
I've got a set of these laying around and I am seriously considering using them on my '72 burb...anybody see any reason why I shouldn't be able to run them?
Slam RS-82 Spec Sheet
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 01-21-2005, 02:50 AM   #2
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
I'd do it. Those are good bags. I'm going with them instead of air lifts
Slam
ModelRS82
Diameter 0 PSI 7.75"
Diameter max PSI 7.75"
Maximum PSI 180
Plate Material Aluminum
Min Height 3"
Max Height 11"
Air lifts
Compressed Height 2.8"
Extended Height 9.5"
Max dia. 6.8"
Max load @ 100 psi 2190
Feature:
- Limited Lifetime Warranty on Crimp Failure
- Aluminum End Caps
- Polyester Reinforced Natural Rubber
- 300 Max PSI Rating
- Single 1/2" Port
- Steel Center Girdle Ring To reduce bags diameter
- 1 Year Warranty on Manufacture Defects
The slam bags will give me 1.5" more raise,and have built in bump stops.
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
