Old 01-23-2005, 02:02 PM   #1
setandreel
setandreel's Avatar
208 rear output seal
Hey All
need some help, my 87 silvy is leaking at the rear transfer case where the drive shaft yoke goes in, now I have replaced the seal 3 times in a month, still leaks? yoke has no scaring I can see or feel, all replacment seals are NAPA someone told me of a speedy seal? Anyone heard of this seal. Or maybe I need to replace the yoke (sure hope not).
Thank you in advance
Mike
setandreel is offline   Reply With Quote
Old 01-23-2005, 04:50 PM   #2
1972
Majician
1972's Avatar
With the driveshaft installed grab it up by the u-joint and try to move it up and down to see if it is sloppy on the output shaft. If there is excessive play it could pull away from the seal as you drive and leak out.
1972 is offline   Reply With Quote
Old 01-23-2005, 06:28 PM   #3
kwmech
If you have any amount of lift the bushing in the tail cone will wear out prematurely, thus letting the slip part of the shaft to move more than it should.
Or is you wnat to spend some money you could get a slip yoke eliminator kit from JB conversions and never worry about it again. I will be alot stronger also.
Old 01-27-2005, 12:43 AM   #4
1972
Majician
1972's Avatar
SYE for a 208?
