Old 07-11-2002, 11:20 PM   #1
robby
Semper Fidelis
robby's Avatar
rear leaf for blazer?
can I use rear leaf springs from other trucks on my 72 K5? I saw some on a 72 K20 and some on a GMC half ton. same year.
72 Chevy C 20 with 402 For sale
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
robby is offline   Reply With Quote
Old 07-12-2002, 02:16 AM   #2
Scrub
Collector of rusty Items
Scrub's Avatar
Are you trying to get heavier springs?
I have a 79 3/4 ton leaf pack under my 70 springs. the 79 pack is longer, but I wanted real heavy springs, so I just used every thing except the main spring from the 79 pack. The second spring is as long as the 70 main spring and that works good for me. You could pull off the 79 main and second spring and have a good set that was close to original.
let me clairify a little. I took my 70 spring pack apart and threw away everything except the main spring. I then took apart a 79 spring pack and threw away the main spring. I stuffed the 79 pack under the 70 main and bolted the mess up.
Works great.
Hope this helps
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 07-12-2002, 07:47 AM   #3
robby
Semper Fidelis
robby's Avatar
My problem is that I have one leaf that is broken. I should have clarified.
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
