01-23-2005, 11:27 PM | #1 |
Ebay Junky
Non-tilt to Tilt, work required?
what work is required to put a tilt steering column into a truck that originally came with a non-tilt column? also, can you still use the column shifter to shift?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain.. 1983 Chevy c10 swb 2wd - possible 350tbi supercharged... |
01-23-2005, 11:29 PM | #2 |
Got Light Emitting Diode?
check the FAQ board. solver did a bad @$$ write up
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
01-24-2005, 12:34 AM | #3 |
its all about the +6 inches
if you have an actual truck tilt...then it is a simple remove and install.
