Old 01-24-2005, 08:43 AM   #1
RED67
Forever Grateful
RED67's Avatar
refurbishing frame ???'s
what is the best way to remove all the caked on crud and surface rust?????
what kind of paint do you use to repaint frame???? and how much does it take and cost??? thx ,red
R.I.P Dad 04-07-42 - 05-27-09
RED67 is offline   Reply With Quote
Old 01-24-2005, 10:01 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Sandblasting is the best way to get one truly and thoroughly clean.
For paint, there are several different options. Places like Eastwood sell frame paint in aerosol cans.
My father in law uses Caterpillar tractor black frame paint. It's about 40 bucks a gallon and ready to spray.
Myself, I use urethane paint just like the outside of the body. You can mix it with a flattener agaent to get the right sheen.
I'd say best option would be to powdercoat it, but it can get pricey.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-24-2005, 03:40 PM   #3
Fat Tom
I've had good results cleaning frames with a lot of time, and a 7" angle grinder with a wire wheel.
69 GMC 2wd 350cid
82 Toyota 4wd, 3.8L V6, 6" lift, 35's, locked and loaded
76 Datsun F10 1.4L ***FOR SALE***
04 Honda Shadow 750
Fat Tom is offline   Reply With Quote
Old 01-24-2005, 04:28 PM   #4
CHEVYE
my gas saver
CHEVYE's Avatar
i am using my little sandblaster to do the inside of my frame rails, and a paint removal wheel on my drill to get the outside and it is coming out very nicely. i`m going to wipe it up with some grease/wax remover and paint it with some eastwood paint i got for $36. i only have a basement garage in my new house so i can`t spray in there without getting everyone light headed. i am applying the paint with a sponge type brush. it looks very smooth and lays out without brush marks.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 01-24-2005, 04:29 PM   #5
CHEVYE
my gas saver
CHEVYE's Avatar
oh` sorry i didn`t even answer your org. ? i used oven cleaner on the frame and sprayed it off, it took out alot of grease and grime.
71`SWB, project
ebay feedback
Old 01-24-2005, 10:10 PM   #6
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I say sandblast it. Takes alot less time!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 01-24-2005, 10:21 PM   #7
rustyold72
rustyold72's Avatar
Sand blasting is definately the best way, but I've used a pressure washer, drill with wire wheel/sanding disc, and a lot of time
I used Eastwoods Rust encapsulator, and a coat of their Chassis Black
71 Chevy C10 "The Rust Bucket"
72 Chevy C10 apart in the garage
02 WS6 T/A Fast Black and bad@$$
93 Nissan Pathfinder "Emily" Totaled RIP girl
05 Jeep Grand Cherokee-HEMI powered
87 Iroc Z28 305 TPI auto (crying out for an LS1 swap)
rustyold72 is offline   Reply With Quote
Old 01-24-2005, 10:37 PM   #8
MrShelley
Too Many Clubs Club
MrShelley's Avatar
I took mine to the powdercoater and let them sandblast it before they coated it.
I'm really happy with the way everything turned out.
How I installed my air bags...
MrShelley is offline   Reply With Quote
Old 01-28-2005, 04:26 PM   #9
BK
BK Built
BK's Avatar
i used a 5" air grinder with 32 grit, then a wire wheel for those hard to reach areas, then painted it using rust stop flat black... looks pretty good, and i really like the all flat black chassis with red accents...
BK is offline   Reply With Quote
Old 02-08-2005, 04:36 PM   #10
Daubs
Daubs's Avatar
Shelley: How much did it cost to have sandblasted and powdercoated?
Did they do leaf springs and axles also? Or just frame?
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 02-08-2005, 06:13 PM   #11
MrShelley
Too Many Clubs Club
MrShelley's Avatar
Let's see....I had the following parts blasted/coated.
Frame
Auto trans crossmember
rear trailing arms
front a-arms (upper and lower)
a-arm cross shafts (upper and lower)
72 BB engine mounts
air bag mounting plates and cups
front crossmember
ECE rear shock relocating brackets
ECE extended panhard bar
ECE raised front swaybar brackets
ECE front swaybar
DJM dropped spindles
steering crossbar
disc brake backing plates
That's all I can think of right offhand. But, suffice it to say, I took a ton of dirty, rusty parts into the powdercoater, and came out with nice shiny parts that make it enjoyable to put back together. And it only set me back $450.
Old 02-08-2005, 07:51 PM   #12
Shev
Head Peon
Shev's Avatar
Man, I always have been under the impression that powder coated a frame was expensive...I consider $450 cheap seeing they had to clean everything up...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 02-08-2005, 07:57 PM   #13
rustyold72
rustyold72's Avatar
For all that $450 is cheap, they want $ 650 up here to sandblast and powdercoat just the frame, nevermind all those extras
