Old 01-27-2005, 06:30 AM   #1
dtlilly
dtlilly's Avatar
Blazer VS. Truck axles
I was just wondering. Are the 4X4 Blazer Axels the same width as the 4X4 truck axels. Meaning... will Blazer axels work on a 4X4 truck?
dtlilly is offline   Reply With Quote
Old 01-27-2005, 08:08 AM   #2
Blazer1970
Blazer1970's Avatar
Yes
Blazer1970 is offline   Reply With Quote
Old 01-27-2005, 09:29 AM   #3
dtlilly
dtlilly's Avatar
Thanks Tim.
Old 01-27-2005, 12:11 PM   #4
72k5
72k5's Avatar
I'm sorry, I don't have more details, but I believe that there is a small issue in the shock mounts. I think the blazers are different from the trucks in some years because the truck shocks go one forward, one back; while the blazer axles have both shocks to the front. Heads up!
350 ETec 170 heads, Performer, HEI, Holly TBI, 700r4, 14 bolt rear, F&R lockers, lots of off road improvements.
72k5 is offline   Reply With Quote
Old 01-27-2005, 05:17 PM   #5
dtlilly
dtlilly's Avatar
So that would just mean relocating the perches, right? Other than that, I could put Blazer axels under a 71-72 Chevy truck, and they would be "as original"?
Old 01-27-2005, 06:52 PM   #6
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I think they should work but I also think there is something different about the shock mountings but I am not sure what?
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 01-27-2005, 09:11 PM   #7
RED72blazer
urban fourwheelin
RED72blazer's Avatar
aren't blazer rear axles narrower than the front?
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 01-27-2005, 09:13 PM   #8
2wdBlazer
The Blazer King
2wdBlazer's Avatar
As long as you stick with the same year range it will definatly work. All the front ends definatly swap. 3/4 and 1 ton rears require the above mentioned mods though. Not sure on late model 1/2 ton rears.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 01-28-2005, 10:28 AM   #9
MJN
MJN's Avatar
as long as you use '67-'72 vintage axles they will bolt in, the shock mounts are the same, everything. The front axles are actually wider on a 4x4 because of an issue with tracking and the handling characteristics of a 4x4. If you're going to run '73 and up axles, the front is the same, but the rear has different shock mounts, one front and one back, and I've heard the spring perches are wider than a '67-'72. Hope this helps some, btw, how's the Blazer from Ashland coming along?
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
