07-12-2002, 11:33 PM | #1 |
Control arm bushings, Help
Does anybody have a trick to remove the bushings from the control arm, the manual calls out alot of special tools, could I just use a bolt in the sleeve and pound it out?
1969 GMC S/B S/S 3" drop |
07-13-2002, 02:43 AM | #2 |
I just did mine about 2 months ago. I replaced all the steering linkage, ball joints and control arm bushings. The bushings actually come out fairly easy with a 3/4" socket set. I bought a cheap set from Harbor Freight Tools for $35.00. The actual bushings look like a very large nut on the end of the control arm shaft - there will also be grease fittings on them unless they've been broken off. I also recomend you replace the rubber grease seals that are on the inside of the bushings. I bought some aftermarket seals/bushings. Bushings were fine but the seals were not made the same and in turn didn't work. For about $12.00 you can still get new ones from your local Chevy dealer that will work great (BTW: they discontinued the original grease seal part number but the alternate part number will work great... They will know what you're talking about).
If you have anymore questions, let me know and I'll see what I can do....
67 LWB GMC 250 inline w/4spd manual Disc/power brake conversion |
07-13-2002, 03:55 AM | #3 |
Bushing replacement
Go Autozone (Loan-a-tool)and get a Crow's Foot If you don't already have one. they pop right out.
71 C10 LWB With Edelbrock 7101& 1406 Carb Accel HEI Blue Print Accel 8.8 Wires Soon to have possi & 186 Camel hump heads Dropped 2-1/2F&4R Dynomax Headers Duals Flowtech Aftburners Tonneau Cover Frm 89 F150 79 Monte C |
