Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 01-28-2005, 10:16 PM   #1
Suicide-D
Location: Katy, TX...but the love of my life resides in Dublin,OH.
Question 97 computer?? needed
I found a low mile vortec 350 complete & tranny out of a 97 truck. I want to put this in my 92.the thing it doesn't have is the computer and harness. Anybody know where I can find one? or atleast what I should expect to pay.
Thanks,
D
Suicide-D is offline   Reply With Quote
Old 01-28-2005, 10:17 PM   #2
Suicide-D
will I need a different fuel pump for it also?
Old 01-28-2005, 11:02 PM   #3
bisquik65
bisquik65's Avatar
You will probally need an aftermarket harness as the 97 harness is also part of the body harness,You also need the mass air flow meter,ecm,and the fuel pump pressure is 35-45 lbs for the vortec motor.. But as far as bolting it in,not a bad job.... Try looking for a harness ,some companys ask you what you are putting it in and what year engine and will make a custom one...Hope this helps some,Erick
bisquik65 is offline   Reply With Quote
Old 01-29-2005, 09:55 AM   #4
NPilot1975
NPilot1975's Avatar
Try painless for your harness and Street and Performance should be able to get you a computer (although finding one at the junk yard would be much cheaper.)
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 01-30-2005, 06:15 AM   #5
oldyeller
Captain CAAAVVVMMMAAANNN!
oldyeller's Avatar
I disagree with bisquik, you will need a pump that can maintain 60 psi. the vortec needs a minimum of 50 psi to start up. most vortecs i have worked on maintain 55 to 62 psi. you might be able to get a tank and all out of a vortec truck and bolt it in yours. it would be easier than trying to retrofit a different pump on to your tank setup.
try http://www.car-part.com for a good idea of junkyard prices...
72 LWB Fleetside C10 Custom 350/350
97 GMC Yukon 4X4 SLT
Anna, Texas
check out the project old yeller
oldyeller is offline   Reply With Quote
Old 01-31-2005, 08:34 AM   #6
Suicide-D
Thanks for the input. Sorry I haven't responded sooner...I have a virus I guess... Shut my whole system down at home.That or I had a hard drive go bad.
Thanks,
D
Old 01-31-2005, 05:30 PM   #7
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
You should be able to just swap in pump and sending unit in your tank. as far as harness goes since you don't have one you can buy for price http://www.paceparts.com/index.asp?P...D&ProdID=73236 and get computer from salvage yard. You also need to consider if you going to keep all yhe emissions or not. I'm still learning on this also,so if I'm wrong on any of this please chime in.
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 02-01-2005, 01:54 AM   #8
NPilot1975
NPilot1975's Avatar
Summit is cheaper than Pace for the painless harness. If you do not keep the emissions, you will need to reprogram the computer, Speartech out of IN can do it for you. I will look and see if I still have there website.
Old 02-01-2005, 08:42 AM   #9
Suicide-D
emissions will have to stay, atleast as long as I stay in this county... which that doesn't look like it's gonna change.
Old 02-01-2005, 09:55 AM   #10
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
Check out some local salvage yards for what you need, I might be able to help you out on the harness if you need a stock one. BTW nice website
Is it Sunday yet???
68 Project
Old 02-01-2005, 12:41 PM   #11
99-2door
99-2door's Avatar
You can modify the stock harness to fit the older trucks. Better than paying over $500 for one from painless.
In fact there is a company on ebay that will do it for you for around $200 I think.
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80
2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc.
2003 Tahoe Z71 Silverado front clip
99-2door is offline   Reply With Quote
Old 02-02-2005, 01:22 AM   #12
NPilot1975
NPilot1975's Avatar
I initially had mine modified, cost me $400 dollars for an LT-1. It had no fuses, lots of electrical tape, and any thing I planned on deleting, the wiring was just clipped and tucked into the loom. I would spend a little more the first time and go with a good harness. I junked the original and got a painless. It hurt for the money but was more than worth it.
Old 02-02-2005, 01:59 AM   #13
99-2door
99-2door's Avatar
Hey Npilot, what did you do to make the AC compressor clear on your truck. Did you just notch? Got a project with an LT-1 in a 70. Thanks
Old 02-02-2005, 08:22 AM   #14
NPilot1975
NPilot1975's Avatar
I went with Street & Performance accessories.
