Old 01-31-2005, 03:42 PM   #1
YellowMenace
Fuel gauge won't show full
I've searched and found some wierd fuel gauge problems, but didn't see this one. Gauge seems to work, except that it shows between 1/4 and 1/2 tank when it is actually full. It goes down proportionally from there as the tank empties.
Will show full when key is turned off. Replaced the sender and fixed the previous problem (pierced float). Tries old sender manually and it does the same thing. I'm sure it's in the gauge itself.
Any ideas.
YellowMenace is offline   Reply With Quote
Old 01-31-2005, 04:07 PM   #2
mtdave2
newly minted old timer
mtdave2's Avatar
i fought with mine for a while too. i went thru 3 floats, not sure what i was doing but they all broke. finaly i got a good one.. id pull the sending unit again, and connect the wire (away front the tank) and manualy move it too the full position, then you can see if the gauge is the prob or not.
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 01-31-2005, 04:40 PM   #3
JimKshortstep4x4
Smile
If you have checked the sending unit output when the tank is full and the ohm reading is 90 ohms then it is probably the resistor on the back of the gauge.
A quick check of the resistor can be made by checking across the posts with the gauge disconnected for resistance from the wiring harness. It should read approximately 35 ohms.
Jim
Old 01-31-2005, 07:24 PM   #4
jhow66
jhow66's Avatar
This should help with your problem:
www.fix-a-gauge.com
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-31-2005, 09:37 PM   #5
Blue Beard
Blue Beard's Avatar
Good link, I have three trucks with gauge issues..
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-31-2005, 10:03 PM   #6
Tim240Z
Tim240Z's Avatar
I had that problem too. Found that the float had a pin hole in it, so it had gasoline in it. Put a new plastic one in and have no problems since.
1972 Suburban C20
454/TH700R4, eaton-corporate 4.10 (looking for 3.7)
Sold: 71 Cheyenne 20
Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005)
Tim240Z is offline   Reply With Quote
