Old 01-31-2005, 05:11 PM   #1
TIMSPEED
TIMSPEED's Avatar
Will brake line work as an airline?
I know, this may be a DUMB question, but, in the next few weeks, I'm going to bag the front of my truck, and I need to figure out what to use for airline. I'm just going to run it from the front bags, up to the firewall, where I'll have a schraeder valve for each side, to fill them.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 01-31-2005, 05:36 PM   #2
Shev
Head Peon
Shev's Avatar
I guess it would work...or if you are looking for cheap and easy maybe 1/4" line would work for ya...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 01-31-2005, 06:05 PM   #3
BK
BK Built
BK's Avatar
i suppose it would work... but if your just trying to stay cheap, i would say run some 1/4" lines, and just run a manual valve, with for say a 3 gallon tank(can hide it anywhere) which a schraeder valve on it instead of a compressor. its cheap, and easy.
BK is offline   Reply With Quote
Old 01-31-2005, 06:21 PM   #4
TIMSPEED
TIMSPEED's Avatar
ok, then, how does airline stay on the brass fittings? Do I have to buy special fittings to fit the airline? I'm doing it even cheaper than having a tank, I'm just gonna run the line up to the top of the firewall, on each side, and pop the hood to fill/empty the bags. This is just a temporary setup, until I have more money, to get rear bags, and valves and compressor/tank setup.
See Them Here
Old 01-31-2005, 07:05 PM   #5
BaggedC10
Under construction!
BaggedC10's Avatar
Why not install standard air line w/ brass compression or PTC fittings? I wouldn't spend the time to bend and secure hard line for a temporary setup.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 01-31-2005, 07:25 PM   #6
TIMSPEED
TIMSPEED's Avatar
Where would I purchase this LOCALLY? My uncle owns a Refridgeration supply house, would they have these sort of things there? (If so, I can get them for free)
See Them Here
Old 01-31-2005, 08:11 PM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Tim, find a tractor trailer repair/supply shop or a service/support operation. They should have the lines/fittings you need.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-31-2005, 09:00 PM   #8
BaggedC10
Under construction!
BaggedC10's Avatar
WORD to what Chris said. If you can't find a local supplier, order everything from www.*****************!
Old 01-31-2005, 09:17 PM   #9
TIMSPEED
TIMSPEED's Avatar
I can't find any fittings on their webpage...i'm just trying to figure out how the fittings connect to the line? Is it a compression fitting type thing?
See Them Here
Old 02-01-2005, 07:33 AM   #10
BaggedC10
Under construction!
BaggedC10's Avatar
Compression fittings are exactly as they sound. Hard to describe over the internet but they are very simple/quick/easy to install. Push to connect fittings are even more simple and if brass, equally as reliable.
Check out www.InnovativeAirSuspension.com too.
Old 02-01-2005, 09:59 AM   #11
XXL
Señor Member
XXL's Avatar
It's OK to be cheap, but don't skimp on something that's iffy if the air is holding your truck up. Busted line often = tow truck.
XXL is offline   Reply With Quote
Old 02-01-2005, 10:24 AM   #12
Shev
Head Peon
Shev's Avatar
I buy all my fittings from www.hoseandfittings.com It's the cheapest place I've found, and it's all Parker fittings. Click on the "Group" tab, that will take you to the D.O.T. stuff (always buy D.O.T. approved fittings and hose for your bags...) You can't beat Suicidedoors price on airline though...
Old 02-01-2005, 10:57 AM   #13
smokekiki
Mike
smokekiki's Avatar
Thanks shev.Less than a $1 a foot for 1/2" and in colors.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 02-01-2005, 12:34 PM   #14
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
Napa has all the stuff you'll need. I use barb fittings and 300 psi hose (the brass barb type fitting that have the plastic piece) . It's cheap, and it's never failed. Just go to Napa
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 02-01-2005, 03:35 PM   #15
Slammed67
Progress = 0%
Slammed67's Avatar
I wouldn't recommend barb fitting for an air ride system. Just because it hasn't failed yet doesn't mean it never will.
Check out McMaster-Carr for air line and fittings. 1/2" air line for $0.72/ft., 3/8" air line for $0.55/ft. in all colors.
Their brass D.O.T. fittings are also reasonably priced. Just a comparison..... a 3/8" NPT male straight fitting is $6.00 at ART..... $4.32 at McMaster-Carr. A 3/8" tee fitting at ART is $10....... $7 at McMaster. 40-feet of 3/8" air line from ART is $50..... $22 at McMaster. With the money you save, you could buy some ART t-shirts and decals and still be ahead of the game
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 02-01-2005, 03:41 PM   #16
XXL
Señor Member
XXL's Avatar
Don't be playa hatin' jus cuz you ain't got the bling
Old 02-01-2005, 11:28 PM   #17
bagged72blaz
Got L.E.D.s
Well they've been on my blazer for over a year. The important thing is they don't rub on anything. I run 1/2" valves and line. And have had the psi up to 170psi. If the hose was going to come off the barb fitting it'd done it by now, and if it's not going to come of the barb fitting and the hose is rated at 300psi I don't see the problem. I work with high pressure hose, all the time. If you where conserned about the hose coming off you could hose clamp them to. Mine is not. The hose is made for the fittings. I'll get part#s tomarrow.
McMaster-Carr is a good place to get stuff. I've ordered from them before.
Old 02-02-2005, 12:00 AM   #18
Shane
Shane's Avatar
I have some 3/8" O.D. line I can sell ya ... how much do you need?
Shane is offline   Reply With Quote
Old 02-02-2005, 02:49 PM   #19
grnddwn
belly dragger
grnddwn's Avatar
Checkout www.fairviewfittings.com
grnddwn is offline   Reply With Quote
Old 02-02-2005, 02:55 PM   #20
TIMSPEED
TIMSPEED's Avatar
Shev,
Thanks for recommending HoseandFittings.com!! I got ALL my stuff, for $20 SHIPPED! (4 fittings, and 14' of 3/8" line)
See Them Here
Old 02-04-2005, 12:25 PM   #21
bagged72blaz
Got L.E.D.s
These are the fittings they are made to be used with FLEX-LOCâ„¢ 300 PUSH-ON Thermoid www.jgbhose.com
