Old 02-02-2005, 01:10 AM   #1
slow69
shop charge for rear main
Quick question... how much would a shop charge to change a rear main seal in a 82 2 wd blazer? It's leaking like crazy, and my house is sold, need to be out in a couple of weeks and I have NO time to change it. Any ideas?
slow69 is offline   Reply With Quote
Old 02-02-2005, 01:14 AM   #2
low 84
low 84's Avatar
several hundred would be my guess. the part is cheap but since they are going to have to pull the motor or tranny they are gonn stick it to you bad for labor
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 02-02-2005, 01:27 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
They shouldn't have to pull the motor. You have a two piece rear seal, so it can be changed by dropping the pan and driving the old seal out....
Old 02-02-2005, 01:47 AM   #4
low 84
low 84's Avatar
wans't even thinking, if you still have an early model block with 2 piece seal they don't HAVE to pull the tranny, but it is a pita to do with everything in there and they are still gonna hit you for some serious cash
'05 1500 Crew Cab
RIP
Old 02-02-2005, 03:18 AM   #5
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
The only real benefit to pulling the motor, is you have everything at standing level (on an engine stand). A 2 piece rear main is VERY simple to do with the engine "in situ". I have done many of them in small block pickups, and have never taken longer than 3 hrs, start to finish.
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
Old 02-02-2005, 09:49 AM   #6
alpha_male0203
95 extended cab sportside
alpha_male0203's Avatar
I just had mine done like 8 months ago on the 81 it was like 350 the guy knew me and gave me like 2 hours of labor off so i got a deal though.
the 81 had a one peice main seal. so i think that yours is as well
95 Chevy k 1500
00 Chevy Silverado 1500
07 cobalt Old ladies car]
alpha_male0203 is offline   Reply With Quote
Old 02-02-2005, 10:05 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by alpha_male0203
....the 81 had a one peice main seal. so i think that yours is as well
Does it have a later model motor? Early 80's small blocks had two piece seals....
Old 02-02-2005, 11:53 AM   #8
gn4u2c
gn4u2c's Avatar
2 piece . that's the only way an 82 would come. unless the motor has been swapped out. I would think they are going to charge you about 3 hrs labor I cannot see more than $250.00 for that job.
If you were close i would do for ya.
gn4u2c is offline   Reply With Quote
Old 02-02-2005, 02:58 PM   #9
mitch1965
mitch1965's Avatar
I just had 2 quotes on my '85, $210 and $275. I sent it in, and it was actually the rear of the intake and a valve cover were leaking. They had to use dye to find the actual leaks because it was so bad
mitch1965 is offline   Reply With Quote
Old 02-02-2005, 07:01 PM   #10
76sierraclassic
I've had a couple of quotes on having mine changed on my 76 GMC and it was going to be less than $200.
Mike
76sierraclassic is offline   Reply With Quote
Old 02-03-2005, 09:20 PM   #11
slow69
thanks for all the input. actually, its a gm goodwrench that I put in about a year ago. I was wondering why it would be leaking since the engine still has just a few thousand miles but I remember that I sat for a while before I installed it so it probably dried out. I think the goodwrench engines still have a 2 piece. I may be able to wait until I have another garage.
Thanks again.
Old 02-03-2005, 11:18 PM   #12
Trimman
Trimman's Avatar
I've put a goodwrench engine in mine back in '95 got tired of changeing the valve cover gaskets once a year. Put a set of edelbrock cast aluminum covers on in '02 have'nt had a leak since.Plus they look good. The stock covers are terrible even with bigger load speaders.
82 C-10 Scottsdale LB owned since 89
350 crate vortec heads Crane 1.6 full rollers
edelbrock 1406
edelbrock performer eps intake
dynomax headers/flowmaster 70's
BTO 700r4 level 3
custom 2 piece driveshaft
12 bolt gov loc w/3.08
Trimman is offline   Reply With Quote
Old 02-04-2005, 12:01 AM   #13
alpha_male0203
the engine it was an 88. sorry about that. yea the egine was an 88 sorry i didnt have then engine in long after i bought that truck. sorry again.
TK SP
95 Chevy k 1500
