Old 02-03-2005, 01:36 PM   #26
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
This is in my 70
454 in front holes, used 72 correct mounts (Fits Great), 350 trans (had to shorten drive shaft 1 inch), , Headers fit perfect (Dynamax) Heater Box not an issue
Lots of fun
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 02-03-2005, 01:48 PM   #27
Purs
Got Big Block?
Purs's Avatar
70cst, are those dynomax headers 2" primaries or 1 7/8? I'm looking for some 2" primary tube headers. thanks.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 02-03-2005, 02:08 PM   #28
Dano69c10
Dano69c10's Avatar
Thanks everyone,
I was going to use a stock 454 and stock exhaust manifolds. If I use stock exhaust manifolds can I use small block engine towers? I have a low hump cab, but I just bought a trans cover and was going to install it. I just installed new urethane cab mounts, but I'll probably put the high hump in anyway. Does any one know if I will need to shorten or lengthen my driveshaft?
I would like to get it done on a weekend without having to make parts store runs, so if anyone has the dimensions for the driveshaft I'd appreciate it. I'm ready to pull some all-niters.
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 02-03-2005, 02:50 PM   #29
1970 CST Short Wide
Senior Moment
For Purs
JEGS
289-86022 Cerama-Coat Headers for Trucks with 396-454ci,
1/2-, 3/4-, 1-Ton Pickup 2WD 1967-87
Blazer/Jimmy 2WD 1968-87
$242.99
I think there 1 7/8
Pittsburg Ca
94565
Old 02-03-2005, 02:56 PM   #30
1970 CST Short Wide
Senior Moment
It is my understanding that if you use SB mounts the stock maniflolds will hit the frame.This happened to a guy I knew a few years back but I dont know what position his motor was in. I used 72 BB mounts and a 350 trans and had to redrill for the rear motor mount and shorten my 1 pieace drivshaft. seems it move everthing back 1 inch, sorry cant remmember the total length somewhere ~57 inches I think
Just food for thought.
Good Luck
Pittsburg Ca
94565
Old 02-03-2005, 04:04 PM   #31
Rdrdave
Broke and still trying
Rdrdave's Avatar
Originally Posted by too much stuff
Couple pics for Rdrdave.
This is a 4x4, not sure what the oil pan is originally, exhaust manifolds are from a 77 chev 1/2 ton. It does fit, just a little tight in places...
Thanks I'll see what happens and post some pics once i start.
Rdrdave is offline   Reply With Quote
Old 02-03-2005, 06:41 PM   #32
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Stock manifolds will not work with small block mount stands.
See the big block motor mount article I wrote in the FAQ for better pictures and details.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-03-2005, 10:00 PM   #33
Dano69c10
Dano69c10's Avatar
Is it true that I will need a different fuel sending unit (3/8" line).
Will an auto trans crossmember out of a 79 chevy truck work or will I need one from a 67-72? The 454 is in a 79 chevy truck. What can I use from this truck.
Will I have to take out the manual trans crossmember under the bell housing in my '69?
What about hooking up the th-400 selector rod to the frame, will my 69 have a place to do this?
I guess I'll need an auto steering column with linkage.
To save myself money, should I forget the th-400 and leave the three speed?Will the three speed be able to handle the 454?
What else will I have to buy to make the swap?
I already have a 4-core rad, but it's starting to look like more than an easy swap.
Don't think I'll be able to get it done this weekend.
Dano
'69 Fleet
