Old 07-15-2002, 08:39 AM   #1
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Small Block ID...Help
Can someone tell me about this motor based on the numbers? Is it a four bolt and what year? Hopefully these are the correct numbers.....
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 07-15-2002, 09:29 AM   #2
JimKshortstep4x4
Smile
Most engine blocks with that code are 4 bolt main engines. If that is a 69-72 block than it is a 4 bolt main engine. (I don't know of any exceptions).
JIm
Old 07-15-2002, 12:25 PM   #3
68 Stepside
huh?
68 Stepside's Avatar
Those don't help a whole lot. It could be:
Casting#---CI------YR-Mns-Model
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
You need the suffix code the front of the block, on the pad in front of the passenger side head, otherwise, it's pretty hard to say what it is.
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 07-15-2002, 12:59 PM   #4
bigjimzlll
bigjimzlll's Avatar
I have had 3 of those blocks in the last year...all of them were 2 bolt mains...they usally do have a higher nickle content though..all in all one of the better blocks
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 07-15-2002, 01:36 PM   #5
1971Stepside
Almost Satisfied
I know it is a 350. I just don't know what year and I am almost positive that it is a 4 bolt as that is what I remember the guy telling me when I bought it. It is not the motor that came in the truck as that was a 6cyl. I am trying to decide if I should have this motor re-built or just by a crate from GM. I want some HP, so I was looking at the ZZ4 engine.
If this is a 2 bolt I will sell it.
What is a 2 bolt worth vs. a 4 bolt?
Old 07-15-2002, 02:41 PM   #6
Southpa
Southpa's Avatar
That casting number spans a lot of years, got it on my block too.
The value is in the nickel content. I was told that the "10" at the end means 10% nickel.
Look at the front pass. side of the block for a machine pad w/ numbers followed by letters (engine suffix code) stamped in. That will give you more specific info on year(s) and application(s).
You can dig up the info at:
http://www.nastyz28.com/spmenu.html
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 07-15-2002, 03:27 PM   #7
COBALT
COBALT's Avatar
Find the ledge in front of the passenger side head (right on the deck). Sometimes it's hidden behind an accessory. Take some brake cleaner and scrub that area clean. There should be a stamped code. The last two or three letters is the suffix. Look that code up to find out what kind of 350 it is.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
