67 is sold
rear brace fabrication after tank install
I took these pics during the installation of my rear fuel cell this past weekend.
I'll remove it once It is properly located to clean up the frame appearance ![]() I removed the rear brace support to clear the tank. I am considering the fabrication of another brace to go between the frame rails or can I just run without anything there? I plan to run a rear roll pan so I am not concerned about the rear bumper brackets. Is there anything else I should be concerned about back there? Thanks! Joe ![]() ![]() ![]() |
I would weld in a substancial (spelling?) brace back there. If you get rear ended, especially with a roll pan, you have zero protection around that tank. If it was my truck, something would be in there.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
no brain no headache
hidden hitch maybe???
btw what fuel cell is that? progress is looking good Joe ![]()
1996 GMC Sierra z71 ![]() 1970 SWB 2wd (project) ![]() |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Fab up a "C" channel of some sort.Maybe some 1"x4" boxed tubing or something.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
I used a chevy luv tank and mounted it under the rear. I had to remove the rear brace but I went back and built a hidden receiver hitch which basically replaced the brace.
67 is sold
That is one of Mark's tanks (FuelCellGuy)
![]() I am interested in putting something there for sure. If memory serves from the teardown, I won't need any of those holes in the side of the frame for anything. Can I just box it in with no problems? Does anyone have a link or a pic of a hidden hitch for these trucks? Thanks. |
Vortec in the works
Is that the 16 gal tank?
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
#8 | |
67 is sold
Vortec in the works
Looks good, I talked to mark other day about my tank just need a few more dollars, if you don'y mind could you tell me how far below the frame that's hanging. Thanks
#10 | |
67 is sold
I'll get the measurements and the other specs tonight ![]() |
67 is sold
Texas 68 -
The tank hangs 3" below the bottom of the frame rail and 3.75" inside the rear of the frame rail. I took a look at my notes, and I have the 7" 16 Gallon tank from Mark. ![]() |
#12 | |
Vortec in the works
![]() Join Date: Mar 2001
Early Classic sells a bracket seperately for the tanks they sell, I think it goes for $45.oo, would most likey be perfect for what you want. Its posted on there website in the gastank section
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
#14 | |
67 is sold
![]() It even has the rear harness hole there... $45 isn't bad either ![]() |
#15 |
67 is sold
Thanks again for the help, I just ordered the ECE brace
#16 | |
![]() Join Date: Jul 2003
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
#17 |
67 is sold
The brace is here
![]() Nice piece as usual from ECE. Now to prime/paint or have it Powder Coated to match the frame ![]()
Joe - Formerly 67c10step ------------------------------- 1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD gr8lakes - My ebay auctions Click here to order forum apparel :: Click here to become a subscribing member Last edited by Joe67; 02-23-2005 at 07:10 PM. |
