Old 02-11-2005, 01:18 PM   #1
woody96
woody96's Avatar
Question Throttle linkage question.....
I just bought a 1984 C10, with modified 305 (cam/headers/duals -w- flowmasters/and Edelbrock 1406 carb and Edelbrock intake)....runs GREAT! SOUNDS INCREDIBLE!!!
Anyway, back to my question-problem-----There seems to be some slop in the accelerator pedal...about an inch of play before I get a feel of engaging or gassing the carb.......I am not sure what kind of carb linkage is on here....is there a way to adjust the linkage and get better feel thru the acc. pedal? The spring on the carb is not too tight...it revs very freely at the carb......ideas??
woody96 is offline   Reply With Quote
Old 02-11-2005, 03:39 PM   #2
beaterC10
It had a cable from the factory, the only adjustment was the idle speed screw.
beaterC10 is offline   Reply With Quote
Old 02-12-2005, 10:31 AM   #3
TrainD5115
North Coast, baby!
TrainD5115's Avatar
Factory carbs had two return springs. Have an assistant check the action of the throttle while you push on the pedal from inside. You might get a better idea of whats happening.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 02-13-2005, 10:45 PM   #4
woody96
woody96's Avatar
Question Throttle linkage...??
Well, did some crawling around under the dash looking at the acc. pedal and the throttle cable...it seems there is a lot of slack before the pedal pulls the cable....I can push the acc. pedal down and there is about an inch of play before it pulls the throttle cable .......any way to adjust this or just need a new cable? How do I install a new throttle cable?
Old 02-14-2005, 12:16 AM   #5
Truckstuff
Truckstuff's Avatar
GM made a few different cables. You cannot adjust them, you will have to find the right style.
Real Trucks are Built not Bought
Building: 1981 GM SB LowRider
1985 GM K3500 3+3
1981 GM K2500 SSB
1980 GM K2500 X-BC Hydro
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Truckstuff is offline   Reply With Quote
Old 02-14-2005, 12:26 AM   #6
badone07
Project 2 Resume
badone07's Avatar
You could also alter your stock bracket or you could get an adjustable throttle cable bracket.
Here are some from Jegs but you can basically find them anywhere...
http://www.jegs.com
John
1984 C30 Chevy Crew Cab Dually
1998 Jeep Cherokee 4x4
2004 Chevy Trailblazer 4x4 (wife's)
1970 Mustang FB fully tubed (getting 521 BBF & powerglide)
1978 Nova 2dr (going BBCaddy & S.P. th400)
1984 Monte SS (circle track car)
badone07 is offline   Reply With Quote
Old 02-14-2005, 09:29 AM   #7
woody96
woody96's Avatar
Question Throttle linkage....
THX all, appreciate the scoop ....I will check out other linkages at Jeg's too-----
It just seems like taking a look at mine, that there is too much slack where the linkage fits into the throttle bracket.......any way to take up the slack with the factory bracket? Which Edelbrock throttle linkage should I go for with an Edelbrock 1406 carb and 84 chevy c10 -w- auto?
Old 02-14-2005, 09:40 AM   #8
beaterC10
Depending on how the cable attaches to the carb, you might be able to cut the end off the cable and shorten it up with a cable clamp.
I drove my truck for several years with the cable stop the PO had installed. It was a small brass fitting that slid over the end of the cable and had a screw that was tightened against the cable. It was installed in place of the factory crimped end.
My only complaint with the aftermarket cable brackets is that they seem flimsy compared to the factory parts. You might see what Edelbrock suggests.
