Old 02-12-2005, 10:13 AM   #1
Tully
help with year of 4x4 chassis
I have a 3/4 ton 4x4 chassis under a 71 GMC 4x2 body. I am not sure of the year of the chassis, it has disc brakes, hub size for rims are 4 3/4" (see pictures), and the front leafs are 3" wide. I posted this in the 4x4 board too but I don't know if you all check that board.
Tully is offline   Reply With Quote
Old 02-12-2005, 01:26 PM   #2
Mudder
Mudder's Avatar
The same guys that will answer you over on the 4x4 fourms will answer you here.
Actually they dont like us 4x4 guys over here on their 67-72 board hehe Thats why Josh made us our own little place on the web over on the 4x4 forums.
Mudder is offline   Reply With Quote
Old 02-12-2005, 01:30 PM   #3
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
There is a number stamped on the left front frame rail, near the power steering pump. It is part of the VIN number but I think it should tell you.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 02-12-2005, 02:24 PM   #4
Rod
Look in the area on top frame rail on drivers side near /just back of the steering box. Post me the numbers and letters there.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 02-12-2005, 05:23 PM   #5
Tully
Rod, there are no numbers where you indicated on this chassis, but I looked on my 72 and they are right where you said. I think the PO put the 3" springs on because the front spring mounts and the shackles are bolted on. What is the first year for disc brakes?
Old 02-12-2005, 09:18 PM   #6
Is it just me or does that rear axle hub look like a FURD hub??? All the 3/4 and 1 ton axle hubs I've seen on these trucks are smooth and round, this one has ridges cut into it. I could be wrong but it's just something I noticed.
RJD
Old 02-13-2005, 07:58 PM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
That second pic is of a 14 bolt rear. 71 is the first year for disc.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
