Old 02-14-2005, 07:15 AM   #1
aitch
aitch's Avatar
Front drop? Spindles? Springs? Both?
I hauled home the 71 Super Cheyenne yesterday. Now the work starts.
I was thinking about 2 1/2 drop spindles and 1" drop springs.
But what happens if I just use 4" drop springs?
Will also be dropping the rear.
Does anyone use car/salvage yard springs that will work in our trucks?
aitch
aitch is offline   Reply With Quote
Old 02-14-2005, 09:04 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
I do not recommend using 4" dropped springs. You will not be pleased with the ride from that short of a spring unless your after a very firm suspension.
I suggest dropped spindles or A-arms and a 2" spring. You can get the same thing buy cutting a coil off your stock spring if they are in good shape....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-14-2005, 07:44 PM   #3
rustyold72
rustyold72's Avatar
If you use a 4" spring alone, you'll have a ride that your kidneys will hate you for,
I'm going with the springs (2" drop) and the spindles(2 1/2" drop), I based it on riding in a friends truck, rode better dropped than it did stock
71 Chevy C10 "The Rust Bucket"
72 Chevy C10 apart in the garage
02 WS6 T/A Fast Black and bad@$$
93 Nissan Pathfinder "Emily" Totaled RIP girl
05 Jeep Grand Cherokee-HEMI powered
87 Iroc Z28 305 TPI auto (crying out for an LS1 swap)
rustyold72 is offline   Reply With Quote
Old 02-14-2005, 07:46 PM   #4
GreyHoundSteve
I just ordered by drop spindles and springs from ECE. I looked at ALOT of different set ups and this seemed like the best.
GreyHoundSteve is offline   Reply With Quote
Old 02-14-2005, 08:43 PM   #5
70short/step
70short/step's Avatar
Did the ECE drop spindles on my 70. Switched to 5 lug disc brakes. ECE is a Great product and they have an excellant support. If you ever have a question while doing the swap, just call them up and they help you out.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 02-15-2005, 07:01 AM   #6
aitch
aitch's Avatar
Can I go to 73+ spindles and rotors at this time? What all is needed?
Old 02-15-2005, 08:53 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, you can use the 73 and newer parts. You'll need to change your upper ball joints and outer tie rod ends.
The lower ball joints are the same. And, brake rotors and bearings are the same from 71-on until they went to the thinner rotors in the 80's.
Reuse your calipers and caliper bolts on the newer spindles.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-16-2005, 08:15 PM   #8
aitch
aitch's Avatar
Rotors
I thought that 73 up rotors were bigger diameter.
