Old 02-15-2005, 03:36 AM   #1
COBALT
COBALT's Avatar
Fixed column....no dome, dash or tail lights???
So I got my column fixed, and for good measure I changed out my plug wires. Pretty good day.
This morning I go out to get in my truck, and there's no dash or dome lights. I figured it was a busted fuse, and sure enough, so I replaced it, and POP, the fuse blows again. Turns out I don't have tail lights either. I have headlights, and backup lights. Just no taillights, and hitting the brakes shows nothing.
So...I did something that's now causing a short somewhere in the engine compartment or under the dash that's blowing the instrument, dome and taillight fuse...
Anyone have any ideas, or am I screwed and have to chase it down with a 12v tester?
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 02-15-2005, 06:40 AM   #2
My guess would be something in the column got pinched, maybe shorting out the wire for turn signals.
Old 02-15-2005, 01:18 PM   #3
greasemonkey
greasemonkey's Avatar
I agree, when I swapped out my turn signal switch I pinched a wire and it was grounding out, and I kept blowing the brake light fuse. Since you were just repairing your column, that would be the first place to look.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 02-15-2005, 03:04 PM   #4
COBALT
COBALT's Avatar
Damn. Actually, that's a good thing, because I don't have to spend a million years tracing all of the wires under my dash. You guys are probably right. The turn signal harness off of the turn signal switch is unbelievably tight in the column...looks like I'll have to take it apart and see where the problem is.
Seattle, WA.
Old 02-15-2005, 04:42 PM   #5
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
dash,park and tail lights are on a different circuit than stop and signal.But the problem may be the same, a pinched wire. Does yours column have a light or fiber optics? Did you have your dash apart? check dash lighting wires.
sneakysnake is offline   Reply With Quote
Old 02-15-2005, 09:09 PM   #6
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
Just like sneaky said, did you have your dash apart more than likely for a column fix? That plug into the back of the dash gauges has flimsy little connectors in it and they can get moved, or distorted. That could be a possible cause.
WRMZ71 is offline   Reply With Quote
Old 02-15-2005, 11:03 PM   #7
COBALT
COBALT's Avatar
I didn't touch my dash, but the plate that goes under the column where it runs past the dash I had to take off to run the harness and the fiber optic through when I took the column apart.
Seattle, WA.
Old 02-15-2005, 11:04 PM   #8
COBALT
COBALT's Avatar
Oh, and there are NO tail lights. It's not just the brake lights I'm missing. I have no tail lights period.
Seattle, WA.
Old 02-15-2005, 11:11 PM   #9
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Unplug the column harness then put another fuse in. If it doesn't blow out then your problem is in column. If it does blow then look else where. Also if the problem is in the column unplug each wire from the connector and then reinsert them one at a time until the fuse blows then you know which wire is your problem. Good luck.
oldiron is offline   Reply With Quote
