Old 02-15-2005, 05:20 AM   #1
tbear
removing fuel tank behind seat, going to fuelcell
whats the best way to remove the tank behind seat.
67-72 GMC long bed
building drag truck so in goes fuel cell.
any advice from the masters out there?
tbear is offline   Reply With Quote
Old 02-15-2005, 08:03 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
make sure it's empty, damn thing is awkward as it is, fuel moving around does not help. I recommend removing the seat first.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-15-2005, 08:17 AM   #3
Joe67
67 is sold
I agree. Remove the seat, Remove the tank cap and grommet, remove as much of the gas as you can (not required), unbolt the tank and sending unit and remove
Post some pics of this truck
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 02-15-2005, 09:11 AM   #4
MOTHERTRUCKERS
I have a brand new never installed 8gallon fuelcell 50.00 + shipping
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 02-15-2005, 10:10 PM   #5
tbear
Is a 8 gallon tank the way to go or whats a good size fo a fuel cell.
plus I live in Calgary, Alberta. need to find good parts/high perf.shop
and also I thought there was more to taking those tanks out! like cutting.
Thanks for the advice guys
Old 02-15-2005, 10:18 PM   #6
XXL
Seņor Member
XXL's Avatar
It's a complete bolt-in. You may prefer to cut the filler neck grommet out rather than fight with it-- a razor knife will do it in fairly easily. Then, across the bottom of the tank, there are a handful of bolts and rectangular washers holding the tank it. Remove the bolts, snip the outlet line on the bottom center of the tank, and it's ready to pull out of the cab. Plan on 1-3 finger cuts due to sharp edges and a 37% probability of shin scrape.
XXL is offline   Reply With Quote
Old 02-15-2005, 10:32 PM   #7
Georgie69
Yah it's extremely easy, I thought the same thing
BTW cut the grommet, soooo much easier.
And if I can do it myself, without scratch's, anybody can.
Georgie69 is offline   Reply With Quote
Old 02-15-2005, 10:33 PM   #8
Dean23
68cst_ss490
Dean23's Avatar
If you arer using it for racing go with an 8 gallon. But if you want to use it for cruising go with a 16 or 20 gallon cell. Try Mopac down there we have one up here and they are resonably priced
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 02-15-2005, 10:43 PM   #9
thisolechevy
I have a 20 gallon cell in my truck and it is just right! Iit is pretty big and takes up some space but I like the way it looks :-) its right in the front of my bed, and it holds just enough fuel for cruising around. On the track though I empty the tank completly and pour in 2-gallons of c-16 for better running and less weight.
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
