Old 02-15-2005, 06:34 PM   #1
hotrodtroy
hotrodtroy's Avatar
HEI Wiring
I was talking to a guy at work today and he said that my HEI doesn't seem to be wired correctly. There is a little black block that is tied to my choke and HEI both. Any ideas????????????????
'72 C-10 w/
'68 Large Journal 327cu.in.
"It's o.k. to dream about what you want to do, until you start doing what you are meant to do." Line from "The Rookie"
hotrodtroy is offline   Reply With Quote
Old 02-15-2005, 09:01 PM   #2
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
Let me get this right. At the black box you only have 3 wires. One of them goes to your distribut, one of them go to your electronic choke, and the other goes straight to the battery?
WRMZ71 is offline   Reply With Quote
Old 02-15-2005, 09:32 PM   #3
Blue Beard
Blue Beard's Avatar
Do a search on the HEI, most that I remember only have a direct hot lead (constant power for the unit)
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-15-2005, 09:38 PM   #4
WRMZ71
WRMZ71's Avatar
no the power wire going into the tach should be a keyed hot 12 volt source. I've never seen one of dem der black boxes before so i was verifying i had the correct info
Old 02-15-2005, 09:39 PM   #5
RainFade
RainFade's Avatar
Get your test light or multi-meter out and check at the choke and HEI key off and in run position.
NEITHER of those should be hot with the key in the OFF position, but rather should be switched so as to be hot in start and run (handy source is the unfused ignition terminals on your fuse block)
Do you have a problem with the battery going dead if the truck sits for some days ?
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes.
My lame K20 page
My lame Eaton disc brake page
RainFade is offline   Reply With Quote
Old 02-15-2005, 10:15 PM   #6
1-PU70
1-PU70's Avatar
Whats in the black box?
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 02-15-2005, 10:48 PM   #7
mr402
Black box looks like it might be a relay. Probably put it in so they wouldn't pull excessive current from the fuse box. Would have the added advantage of supplying a few more volts to the distributor too. Could even be used so the resistor wire switches it on. That way you wouldn’t have to go through the dash with an unfused wire. Relay should have a wire to the battery and a wire from the ignition source going in. Output would power the electric choke and distributor.
mr402 is offline   Reply With Quote
Old 02-15-2005, 11:29 PM   #8
hotrodtroy
hotrodtroy's Avatar
Guys thanks for the responses.
I'm not sure what the black box is or what it has in it. There are three wires coming out of it, (1) TO THE DISTRIBUTOR (2) TO THE CHOKE, and (1) coming into it straight from the battery. I haven't checked to see how it gets it's switched power. The tach lead is not connected YET. I have left it sitting for up to two or three weeks with no real problems starting, (except for the float bowl draining). I will trace it all out this weekend to see what I can see.
Thanks Again,
Troy
'72 C-10 w/
Old 02-15-2005, 11:54 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If it was getting constant power, the engine wouldn't shut off, so the black box is switched from the ignition at one point or another. Like said before, that looks to be a relay, and if it is, then just leave it alone. That is a better way of doing it than all of us going to the fuse box.
Old 02-16-2005, 12:45 AM   #10
krue
Designated A-hole!
krue's Avatar
If it works, why mess with it? Looks pretty clean so I probably wouldn't mess with it if it were mine.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 02-16-2005, 04:43 AM   #11
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
It's prob. being triggered by the electric choke.
It's a relay,you can bet on that.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 02-16-2005, 12:41 PM   #12
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
it's just a splitter box it looks like...there is one under my hood for some other stuff....
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 02-16-2005, 02:43 PM   #13
john
member #16
john's Avatar
That box is part of the electric choke conversion kit. I had one that looked just like that. I think it a heat sensitive switch to regulate choke operation. I have no idea what the dist. wire is unless it is the pos. switched power being picked at that point. It should not have constant 12V power. John
john is offline   Reply With Quote
Old 02-16-2005, 08:19 PM   #14
hotrodtroy
hotrodtroy's Avatar
Thanks Again
I am thinking about putting a switch in the hot side as a kill switch. Insurance guy said it would lower my cost a bit. But, any little bit helps, Right?
'72 C-10 w/
