Old 02-17-2005, 11:02 PM   #1
skokie
skokie's Avatar
How do you check the brake booster?
This is not on my 68 chevy but on my 182 ton 01 sierra. How would you check to see if the booster is working ok? I just did a brake job but it feels like there is no booster there at all. Was the same way before the brake job to.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 02-18-2005, 12:11 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
All the ones that I have ever had to go bad make a hissing or sucking sound,you might check your vac line from the manifold to the booster for cracks and leaks.
sneakysnake is offline   Reply With Quote
Old 02-18-2005, 12:18 AM   #3
skokie
skokie's Avatar
Its not hissing and also it is not hard either. Forgot to mention that. Could it be the master cylinder? What are the symptoms of a master cylinder going out?
68 build thread
Old 02-18-2005, 01:26 AM   #4
Solver
Solver's Avatar
I always just pull the booster vacuum line and if the truck stays running then it is probably bad
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 02-18-2005, 02:47 AM   #5
avejoe
Custer had a plan too.
avejoe's Avatar
To check the booster....
With key off, pump the pedal a couple of times and it should firm up. Hold your foot on the pedal and start the truck. The pedal should fall about .5 inch.
If the booster does this then it should be ok for its designed assist. Mine checked out but would not stop the truck. I ended up buying a dual diaphram booster.
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 02-18-2005, 10:45 AM   #6
sneakysnake
usually leaking or wont make a pedal.You might try unhooking the vac line and check to see you have good vac,try your pedal with and without the vac line hooked up see any difference.
