GO VOLS!
antenna wire
where does the antenna wire go through to the inside?
http://1972blazer.shutterfly.com/<= blazer build pics It's called golf because all the other four letter words were taken. It's easier to ask for forgiveness than for permission. |
![]() Join Date: Dec 2002
Theres a hole behind the glove box that sits in the corner. stick your head in there and look towards the antenna. I don't really know if there was an actual whole in the design for it or some guy in the factory with a drill. I have seen them in different widths away from that corner, but in that general area. The hole is just enough to get the end through
This is on a 72 Blazer--there is a hole on driver side removable cowl the size of the ones on pickups and a hole (3/8") on pass side. Here is the catch--no hole in cab cowl to inside!
(orangeuavol's dad)
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Thanks Gee Emm. If they came from factory with no radio would the hole still be there? This one has no hole.
If they did not have a radio, then the hole was not drilled. The hole is a nominal 5/8" to fit the factory grommet that is on the antenna wire.
When installing them sealing arond the grommet is recommended as they are a leak source. Jim |
I don't believe my 69 had come with a radio but the hole was there just like any other truck. I think it is one of those whimsical factory things.
Gee Em,
There are plenty of those! The trucks that I have seen without the hole don't have the speaker bracket holes drilled either. Could be a year thing or assembly practice. Jim |
Thanks fellows.
