Old 02-23-2005, 06:15 PM   #1
wolfthing2000
3/4 ton brake assemblys
I have a 69 3/4 ton with corporate eaton style rear axle. I believe the brakes are 2x12 ( I haven't gotten in there yet to measure. I have a rear axle out of a 72 that has what looks like bigger brakes. The stud size is also bigger on the hubs for the wheel lug nuts. Will the bigger brake/ hub assemblys bolt on my 69 axle????
ThaNKS,
Dave
wolfthing2000 is offline   Reply With Quote
Old 02-23-2005, 06:31 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I believe so. You plan on swapping the backing plate and the hub? The studs should be 1/2" on the 69 and 9/16" on the 72.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-23-2005, 10:04 PM   #3
Dean
Dean's Avatar
I've done this swap before and you will have to swap everything....backing plate, wheel cylinder, hardware, drum, shoes & etc.
Dean is offline   Reply With Quote
Old 02-24-2005, 07:31 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Please think about this a second before you dive in.
If the bigger brakes are the 15 inch size, you will pay very, very dearly for brake parts.
Wheel cylinders run 70 bucks and shoes 130 bucks. Thats near 300 bucks for just a basic brake rebuild.
I'm in the middle of this hell on my 72 dually right now.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-24-2005, 12:08 PM   #5
wolfthing2000
I do believe these are 12s but wider than the 69s. Yes I would transplant everything.
Dave
