How do we get 5 lugs for rear?
Hey Yall,
I have a donor '86 for the front suspension, brakes, etc., but what has been done to get the rear axle to 5 lugs, short of clipping the trailing arm brackets? Are there any other rears that the axles will swap? ANy ideas or info will be REALLY appreciated. Thanks |
71-72 rears will bolt right in
Have the axles and drums redrilled for 5 lug.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
![]() Join Date: Jun 2002
I've done it both ways but changing in the whole rearend from a 71-72 chevy truck is easiest, unless you are a machinist...
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
CCRider
Chevy duty has a kit that you can use to "bolt in" the 86 rear end (requires welding)... Part # 93-313
http://www.chevyduty.com
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
Thanks for the posts, I'll probably go with the "bolt-on" kit, to save my 67 rear from getting chopped up. Thanks Again
A classic GM kinda guy
Check with either Early Classic Enterprises or Classic Performance Products for 5 bolt axle conversions. Here are their web addresses:
www.earlyclassic.com www.classicperform.com
Old school rap music: a dual exhausted GM 6 with no mufflers. "If you can find a better vehicle, buy it" Lee Iacocca, Chrysler commercials of the '80s. "I did. They are called Classic GM pickups !!!" ![]() ![]() |
blood type; Retumbo
what I have is a 70 coil sprung rear under my 68 GMC. then I swapped the axles from a 80 donor truck. this also required the use of the 80 brakes to go with the later drums. it all bolted righ up with no problems.
I hope this helps
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
