Old 02-24-2005, 01:27 AM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
now im pissed.......all i had was them female connectors with plastic over them so i took a razer and was cutting it off and sliced 2 of my fingers real bad....then i took the torch and burned the plastic off and the dam thing still wont fit....i think someone should take pity on me for being so stupid and send me a plug lol note the bandaged razor sliced finger lol......
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 02-24-2005, 04:28 AM   #2
67ChevyC10Stepside
where to get temp wire end?
where can i get the fitting that hooks to the thing in the block for temp?
Old 02-24-2005, 04:29 AM   #3
cableguy0
just use a regular female spade connector
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-24-2005, 05:00 AM   #4
incoma
incoma's Avatar
I did just as cableguy0 says. Works fine. I even have the special kind with the extra prong on it. That way if I ever find the plastic clip that's supposed to go on it, I can just snap it in and be fancy.
incoma is offline   Reply With Quote
Old 02-24-2005, 05:12 AM   #5
67ChevyC10Stepside
it's a round post....how will a female connector go on a round post? i have the ones with plastic on them to shield them some from water...do i have to take that off?
Old 02-24-2005, 05:14 AM   #6
cableguy0
because its thin and wide enough for the connector to hold all the stock connector is is a spade connector surrounded in plastic
Old 02-24-2005, 11:11 AM   #7
67ChevyC10Stepside
ttt
Old 02-24-2005, 11:19 AM   #8
greasemonkey
greasemonkey's Avatar
Just get the female connector that doesn't have the insulation around the connection part, don't make it harder than it is man.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 02-24-2005, 11:25 AM   #9
67ChevyC10Stepside
there isnt any insulation on that one....am i stupid or what? i just dont understand how the post can get into that tiny little crack between the bent over pieces.....if im an idiot im sorry.
Old 02-24-2005, 11:27 AM   #10
Alexis
Member since 2000
Alexis's Avatar
you can get the connector at a hardware store, stereo shop, auto parts store, disney land, flea market, hell you might actually have one laying around somewhere.
I think you'll find someone in in San Fran to take pity on your stupidity and sue the razor company for not putting a warning on the blade that the razor is sharp and can cut you if not handled properly........how where you suppse to know it was sharp enough to cut your skin..................
Alexis is offline   Reply With Quote
Old 02-24-2005, 11:31 AM   #11
greasemonkey
here I scrounged this pic off the board for ya, don't have any of my own.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
Old 02-24-2005, 11:32 AM   #12
CUSTOM/10
CUSTOM/10's Avatar
Temp wire end
I also used a female push on connector, and it worked fine. If you have to spread the connector slightly with a small screw driver, and test fit it before crimping it onto the wire.
Gary
CUSTOM/10 is offline   Reply With Quote
Old 02-24-2005, 11:38 AM   #13
67ChevyC10Stepside
thanks guys....i think i should get at least 50 thou for cutting myself.....like you said how should i know? i thought it was only for cutting plastic :/
Old 02-24-2005, 11:38 AM   #14
67ChevyC10Stepside
on another note......at least the scar will be perfectly defined and perfectly straight....brand new razor blade pushing into plastic then slipping doesnt like hands very much.
Old 02-24-2005, 11:42 AM   #15
greasemonkey
I cut off the very top of my finger when I was ten with a Swiss Army knife.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
Old 02-24-2005, 12:02 PM   #16
67ChevyC10Stepside
ouch.....i've never cut anything off.....im a bag of scars though.
Old 02-24-2005, 01:33 PM   #17
70 longbed
NAPA has the connector you are looking for, but probably not the connector body. It is a GM 56 series (Packard 56 series) female. Mad electric also sells them, and sometime even the local parts stores might have them. The connector body is another story. You need the one with the slot in it so it slides down over the button.
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 02-24-2005, 01:42 PM   #18
1-PU70
1-PU70's Avatar
Look here
http://www.ecklers.com/product.asp?d...D42RWQ7BW2BPB8
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 02-24-2005, 03:41 PM   #19
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Well if worse comes to worse you can go to the salvage yard,and cut one off a donor and then use a butt connector and splice it onto your wire,and plug it in.
Or wrap the wire around the sender,and duct tape it :P
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 02-24-2005, 04:25 PM   #20
70 longbed
I forgot about that setup 1-PU70 is referring to. That is a sweet setup. You get the correct color wire, connector and housing, and the original style heat sleeve. It was in a post a few days ago also, may have been 1-PU70 then also.
Keith
Old 02-24-2005, 05:26 PM   #21
71-longbed
Its Magically Delicious
71-longbed's Avatar
i used a regulat spade connector .. had to widen the gap alittle .. but it works just fine
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 02-24-2005, 05:30 PM   #22
71-longbed
71-longbed's Avatar
think i got the name wrong
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 02-24-2005, 06:58 PM   #23
SLS
Finish the'71..or bust!
SLS's Avatar
Strip the wire bare and tack weld that sucker on.
Just don't burn yourself...or you will have to sue the welding machine manufacturer too.
SLS is offline   Reply With Quote
Old 02-24-2005, 08:18 PM   #24
avejoe
Custer had a plan too.
avejoe's Avatar
Is the "tie a wire around it and use duct tape" for his finger or the temp sender?
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 02-24-2005, 08:54 PM   #25
VetteVet
Msgt USAF Ret
VetteVet's Avatar
here's a novel idea. Go to the junkyard and find one on an older car or truck and cut about six inches of wire off with it and then splice it into the wire on your vehicle. Then drink three beers and the fingers won't hurt so bad.
Remember, it goes on the end of the sender at a 90 degree angle not straight on.
Most horns have a spade connector on the wire with the plastic cover. Not the same but it should work,
Vettevet--old and scarred
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
