02-27-2005, 08:46 PM | #1 |
Ebay Junky
Fuel injection for sale
I am selling my tuned port fuel injection, the price is $850. it is a complete setup from a 91 vette, all you need a distributor from a 90-91 vette with tpi or a iroc with tpi or a firebird with tpi, and a fuel pump.
Complete painless wiring harness, computer and accessories. This unit has 950-1000 cfm. Single wire installation. It is rated for 350-450 horsepower. Has all sensors and part numbers. Polished top and fuel rails. Also chrome K and N air filter. Will fit 1965 to present small block Chevy V-8, older blocks will need to have the intake bolt holes enlarged. the throttle body has two butterflies. the opening measures 7.5mm by 12mm. it has 26lb injectors, the kit has adjustable chrome regulator, injectors are bosch, according to previous owner, the unit only has 20,000 miles on it, it could use a cleaning, but otherwise its in good shape.
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain.. 1983 Chevy c10 swb 2wd - possible 350tbi supercharged... |
02-27-2005, 08:49 PM | #2 |
Ebay Junky
2..
02-27-2005, 08:53 PM | #3 |
Ebay Junky
i forgot to mention, the unit comes with a new stainless polished bolt kit.
02-27-2005, 09:43 PM | #4 |
So this will fit my 82 350?
02-27-2005, 09:50 PM | #5 |
All you have to do is enlarge the center bolt holes on the intake. It is a common mondification on the later intakes.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
02-27-2005, 11:05 PM | #6 |
computer out of the Vette also? What did you do for a engine, did you end up using the 383?
Later, Darren |
02-28-2005, 12:32 AM | #7 |
Ebay Junky
yes it will work on your 82 350 with the bolt enlargement, i planned on putting on my 383, but ran out of funds before i could do so. I beileve the computer is also out of the vette.
02-28-2005, 07:04 PM | #8 |
Ebay Junky
ttt
03-01-2005, 11:13 PM | #9 |
Ebay Junky
how about $800?
03-02-2005, 01:19 AM | #10 |
parts
What's all needed to make this work ? I assume a painless wiring kit. What about sensors ? Are these units fussy about the cam used ?................Thanks..........Zoomy
03-02-2005, 04:16 AM | #11 |
Ebay Junky
everything you need is there, except a distributor and a fuel pump, i'm not sure what you mean by sensors? usaully a small block with 350+ hp has a pretty decent cam, and thats what this unit was set up for.
03-02-2005, 12:28 PM | #12 |
Mike
It is a corvette intake.You can tell by looking at the dist hole.The boss for the hold down runs straight with the back edge and there is a an egr valve hook up right in front of the boss,which is caped off in the photo.Vette intakes will work with pre 87 heads without mods.It is the camaro intakes that need the holes at a different angle.The only difference in a vette computer and a camaro computer is the vettes is water proff for use under the hood.Pretty good deal,considering the price the harness,larger injectors and throtle body.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
03-03-2005, 07:57 PM | #13 |
Ebay Junky
ttt
