Old 03-05-2005, 11:40 PM   #1
boraxman
Keepin an eye out
boraxman's Avatar
3-5 spring drop...
Has anyone done this drop? Right now I have cut springs up front and heated in the back. It looks like a saggin 2-4 drop as these are original springs.
Im thinkin 3-5 will be close but I dont want alignment issues.
I already have shock relocators and a adjustable trac bar and will probably get new shocks w/ the springs.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 03-07-2005, 12:00 AM   #2
boraxman
Keepin an eye out
boraxman's Avatar
Come on anyone using 3-5 spring combo?
ZIP 91351
Old 03-07-2005, 08:45 AM   #3
70c10
67-72 Addict!
70c10's Avatar
I think Tim Christian did this on his sons truck and maybe Gene also. Their trucks look great!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-07-2005, 09:51 AM   #4
Purs
Got Big Block?
Purs's Avatar
Mine is supposedly has 3" springs in the front and 4" springs in the rear. I don't know for sure because I bought the springs slightly used and didn't see any numbers on the springs. Personally I think it sits about 1" too high in the rear. As far as alignment, It seems to ride and drive just as good as it did before (which is pretty darn good.)
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 03-07-2005, 10:44 AM   #5
ChevyDude
Nice Rallys Brit!!!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 03-07-2005, 11:33 AM   #6
A few 72's
A few 72's's Avatar
Here's the truck, maybe Tim can give some numbers...
A few 72's is offline   Reply With Quote
Old 03-07-2005, 02:13 PM   #7
Purs
Got Big Block?
Purs's Avatar
thanks Alex. Now if only they were real.... They widest they make is 17x8's in the chrome ralley's and I'm dead set on 17x9.5's in the rear, SOOO it's either fork out the $$ for the Billet ralley's (which you can get in any width) or go with something different....
Old 03-07-2005, 02:58 PM   #8
Exille
woah....is it just me or is the rear bumper tweaked?
Exille is offline   Reply With Quote
Old 03-07-2005, 11:25 PM   #9
racer6
looks tweaked to me....even with my head turned sideways..i like the rolled pan look myself
racer6.. slightly burned out, but still smokin'..
racer6 is offline   Reply With Quote
Old 03-08-2005, 10:33 PM   #10
purple gas
Tweaked definatly tweaked........... Damn were a picky lot.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 03-08-2005, 10:50 PM   #11
69 longhorn
3/5, with 1 1/2" body drop tossed in.... http://community.webshots.com/user/hotrodhorn L
69 longhorn is offline   Reply With Quote
Old 03-09-2005, 02:43 AM   #12
boraxman
Keepin an eye out
boraxman's Avatar
Thats one cool truck!
ZIP 91351
Old 03-09-2005, 03:15 AM   #13
Low68
Low68's Avatar
Here is mine. It has a 3.5/5. I haven't had any alignment issues that I can remember, but then again, I have had so many problems with everything else that I could have just forgotten
Build Thread
Low68 is offline   Reply With Quote
Old 03-09-2005, 05:39 AM   #14
67shortie
Green club
67shortie's Avatar
Low 68, have always liked your truck, that's one sweet ride
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 03-09-2005, 09:52 AM   #15
boraxman
Keepin an eye out
boraxman's Avatar
Very nice Low68. I ordered my 3-5 springs w/ new gas shocks from Athey's Classic Truck Parts and took advantage of the 10% off offer they have going this month. Fresh suspention makes me happy
ZIP 91351
Old 03-10-2005, 02:58 AM   #16
Low68
Low68's Avatar
Thanks, I appreciate it.
Low68
Build Thread
Old 03-10-2005, 09:57 AM   #17
72 Cheyenne402
72 Cheyenne402's Avatar
PURS What size rims and tires are you riding on? Are those rally's
72 Cheyenne402 is offline   Reply With Quote
Old 03-10-2005, 10:03 AM   #18
Purs
Got Big Block?
Purs's Avatar
they are 17x8 wheel vintique rally's with a touch of Photoshop
Old 03-10-2005, 11:39 AM   #19
72 Cheyenne402
Could I ask the cost per wheel and do they come in 17x9 or 10's? They look really good on your truck
Old 03-10-2005, 12:17 PM   #20
Purs
Got Big Block?
Purs's Avatar
They don't make the steel rally's in anything wider than 17x8 I had a long conversation with the guy at wheel vintiques and he said the only way to get the rally's wider was to buy the billet rally's that are around $300 each Disappointing to say the least.
Old 03-10-2005, 12:20 PM   #21
72 Cheyenne402
How much are the Steel versoins
Old 03-10-2005, 12:20 PM   #22
72 Cheyenne402
in 17x8
Old 03-10-2005, 01:07 PM   #23
72 Cheyenne402
I have a 2-1/2" drop spindle in the front and a 4" lowering spring in the rear. on a LWB. It looks good, w/15x8 245-60-15 and 15x10 295-50-15. I want to go bigger with the rim size and also use a blazer style tank. I wouldn't recommend going with a 4" spring in the rear if you plan to use a rear mount tank. I've got to pull my 4" and try a 3" due to the rear end may set lower than the front.
Old 03-10-2005, 06:50 PM   #24
race-n-jason
-Praise the Lowered-
race-n-jason's Avatar
here's a long bed with 3/5 spring drop....
bought them from CPP
Race-N-Jason
('71 Chevy C-10 LWB 454/TH350)
('07 Dodge Ram 2500, 5.9 Cummins/6-speed Manual)
race-n-jason is offline   Reply With Quote
Old 03-10-2005, 07:07 PM   #25
shifty
Questionable
shifty's Avatar
Hey, Jason, your truck looks pretty damned low compared to the other guys with the same drop. How is your ride with only using springs to drop it? About the same as stock, too stiff, or a little squishy?
What size wheels you got?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
