Old 07-22-2002, 06:08 PM   #1
sewanhaka62
gas gauge
hi
have a gas gauge that doesn't work--how can i check it
it is a 1967 c10 with the standard 3 pod inst. panel with idot lights
what does the pink wire do ?
the tan ?
does the tank wire plug into the fuse block[marked fuel]
thank you
bob
sewanhaka62 is offline   Reply With Quote
Old 07-22-2002, 06:26 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
What exactly is your guage doing?
Yes, the brown wire goes to that tem on the fuse box.
Old 07-23-2002, 07:10 AM   #3
sewanhaka62
hi
i picked up a solid truck that was striped---replaced the front and under dash wiring from another 67 truck--put a new sub. tank and sender in rear---gauge always reads full---grounded the port at fuse block with no diference in reading
thanks
bob
Old 07-23-2002, 06:07 PM   #4
Longhorn Man
If it is right at the FULL, and does not respond to grounding the guage wire, you are probably looking at not having power to the guage...the 12 volts to the back of it.
If it is way past full....like at the 3 o'clock position, you have the fuel sender wire grounded somewhere.
Being that you have chainged to another kind of tank, this may make things a little interesting, but troubleshooting should all be the same in reality.
Old 07-23-2002, 06:48 PM   #5
Longhorn Man
I'm starting to doubt this....some one confirm or deny this for me...it's been too long.
