Old 03-12-2005, 05:29 PM   #1
68racer
Yeah baby!
68racer's Avatar
Caliper Question
I'm swapping to a later front suspension clip before the 502 goes in. Over the years I have been collecting parts. I now find the recon calipers have a 3/8 UNC thread for the hollow hose bolt. The hoses have a 7/16 hole in the end. The hollow bolts that came off the old clip are 7/16 UNF.
At what year did this thread change?
If I get 3/8 UNC bolts can I use the hoses with the 7/16 holes?
If not, what is the part number or year for 3/8 hoses?
I have set the chassis and lines so that the hoses run down the top front of the upper arm.
Due to my location in the UK I can't ask at the local car spares outlet .
Any help appreciated!
11.37 @116
68racer is offline   Reply With Quote
Old 03-13-2005, 03:51 PM   #2
68racer
Yeah baby!
68racer's Avatar
Actually guys i could do with some help on this one.
What years on 70's trucks had 3/8 UNC holes in the calipers and which had 7/16 UNF?
11.37 @116
Old 03-13-2005, 11:56 PM   #3
72402
Don't know what year they changed, but I think you'll find that they are actually 10 mm instead of 3/8. I doubt if they'll work with the 7/16 lines. I ran into this recently using a set of spindles and brakes from a 91 Suburban on a 67 pickup. I believe the bolts were listed as 10mm-1.5, the 1.5 being the length. Hope this helps a little. Frank
72 Cheyenne SWB Fleet/original 402, TH400, buckets & console
65 C10, 350TBI, 700R4 (work in progress)
72402 is offline   Reply With Quote
Old 03-14-2005, 05:45 PM   #4
68racer
Yeah baby!
68racer's Avatar
Yep, that's sorted it, thanks Frank.
11.37 @116
