WTB Hand throttle 67-70
I need a dash mounted hand throttle (with the little THROTTLE badge) that goes behind it. V8 engine it is a thru the firewall type. Thanks in advance!
68 K-10,79 K-10,80 C-30 57 chevy convertible 79 Z28 |
I will keep my eyes out for one. Do you want the entire set up, and what year is it for? My 72 GMC has the option, and I am sure there is one out there so I have plans to hit a huge truck salvage yard over the next month in S. Central Ozarks, and I will see if I can set you up, but in the meantime someone on the board may have one.
Tim |
1968
Thanks O. Tim
It is for a 68 v8 with mechanical linkage. I don't think the one for a 71-72 will work. Thanks again
Hand Throttle
687980Chevy - I have the cable end, linkage adapter bracket, and plastic dash nameplate. I am willing to sell only 1 of the nameplates. I do not have any cables for sale. $25.00 plus shipping.
![]() This is for 687980Chevy first.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Put me in line behind 687980Chevy.
Bob
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
Bob Moore,
Sent you a PM Thanks
Bracket Install Photo
687980Chevy - Here is a photo showing the hand throttle bracket attached to the linkage. Note the bolt is in the lower hole on the arm with the head to the midline and the nut on the outside. The cable stop is forward on the tab to provide pulling action. The cable comes through the firewall at a spot dimpled by the factory. I would recommend installing the bracket on the arm and then line up the cable to find the location. The firewall pad has a prepunched tab that needs to be removed to reveal the dimple from the inside.
Be careful when cutting the hole in the gauge cluster. A Dremel works best in my opinion. The location is plain to see on the reverse side of the bezel. The hole already exists in the metal part of the dash. ![]() Total will be $27.00. I do not have pay pal. A money order would be great. Address was furnished in my PM. BobS - Sorry I only have one to sell at this time. If I come accross another I will put you 1st in line.
Thanks Bob, all I really need is the cable end, I've got all the other parts. If you or anyone else happens to find one somewhere I'd appreciate hearing about it!
Bob
Sent another PM
Thanks Bob!
