Old 03-16-2005, 12:48 AM   #1
krue
Designated A-hole!
krue's Avatar
What do I need to do before driving this thing?
I have a 72 blazer 4x4 that has sat for a long time. I want to at least change fluid in both diff's, remove covers and inspect (and see what ratio). I also need new seals for the hubs (had to remove them to load it on the trailer.) What else should I check? I plan on rebuilding the brakes before driving it.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 03-16-2005, 03:07 AM   #2
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Make sure all your turn signals and lights work. I would do an oil change if it has been sitting for along time. Check tranny and transfer case fluid if possible.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 03-16-2005, 03:14 AM   #3
krue
Designated A-hole!
krue's Avatar
My brother changed the oil and put a tune up on it trying to get it to crank, so I'm covered on that. What kind of oil does the tranny (3 speed) and xfer case (no clue) take. I assume the differentials get 90w.
www.daveramsey.com
Old 03-16-2005, 07:43 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
put 90w in them also.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-17-2005, 01:06 AM   #5
GMC71k20
check all fluids, and best bet is too take an easy maiden voyage in a safe area to find the problems. i found out i had bad brakes for the first time at a busy intersection with a day care center crossing the street
GMC71k20 is offline   Reply With Quote
Old 03-17-2005, 02:59 AM   #6
krue
Designated A-hole!
krue's Avatar
I have 5 acres to test drive on, hopefully everything will work.
www.daveramsey.com
Old 03-17-2005, 01:46 PM   #7
Hoods69BadBowTie
Chevys Kick A$$
Use 80-90 Weight gear oil in the transfer case. I used some kind of ATF in the transmission. Can not remember exactly what it was though.
-Later
-LATER
Old 03-18-2005, 06:54 PM   #8
vtblazer
vtblazer's Avatar
Another thing to do is to get on your creeper and with an assortment of wrenches go front to back and tighten EVERYTHING you can possibley get to.
You'll be surprised on how many turns will be needed.
Grease the u-joints and slip joint too.
Checking the front wheel bearings isn't a bad idea either. Just jack up one side at a time and rock the wheel top and bottom.
Have fun.
vtblazer is offline   Reply With Quote
Old 03-22-2005, 02:38 AM   #9
Americanrider
Might be a good idea to purge the gas lines w/ compressed air and get a cheap in-line gas filter. You never know what will crawl out from the bottom of your tank and gunk up your carb. Also take the time to flush the cooling system a take a peak at your themostat, it may have rusted shut.
Americanrider is offline   Reply With Quote
