03-16-2005, 01:10 AM | #1 |
Metal Fuel Line WIth Filter
Does anyone know if it is possible to get a screw in metal line from your qjet to a external fuel filter? I thought I saw one on a engine pic posted up here. I will see if I can locate the pic.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
03-16-2005, 01:40 AM | #2 |
Ok found the pic..
03-16-2005, 02:34 AM | #3 |
User #12137
thats a qjet carb ?
i like the fuel filter and line though never seen one like that |
03-16-2005, 02:52 AM | #4 |
I think that the carb is a edelbrock.
03-16-2005, 07:19 AM | #5 |
Active Member
Summit has those. EDL-8131 or EDL-8134
http://store.summitracing.com/partde...0&autoview=sku |
03-17-2005, 12:09 AM | #6 |
its all about the +6 inches
not only can you do it..but you should. That is the best place to install it.
03-17-2005, 12:23 AM | #7 |
But the question is can you put on a qjet?
03-17-2005, 07:06 AM | #8 |
a fuel line is a fuel line....don't matter if it is hooked to a q jet a edelbrock or a toro sprinkler....
03-17-2005, 07:09 AM | #9 |
Active Member
Q-jets and EPS carbs are basically the same.
03-17-2005, 08:53 AM | #10 |
Watch out for your cornhole !
Brad, you're going to have to bend and flare the lines yourself to get that setup on a quadrajet.
What's wrong with the stock fuel filter in the quadrajet? I always run them, along with an inline under the truck between the tank and the framerail. That gives you one before the pump and one before the carb.
03-17-2005, 12:23 PM | #11 |
Kevin,
Nothings wrong with the stock fuel filter. Just curious.
