Old 03-17-2005, 08:12 PM   #1
Razor454
Razor454's Avatar
Backspacing on rims
Question, what would be a good backspacing on the front and rear of a 1967 chevy truck.
Information:
-The truck has disk brakes all the way around.
-The measurements are 65" hub to hub in the front and 64" hub to hub in the rear.
-Will be installing 18"x7 or 8 Bonspeed Clutch rims.
-Installed a 2/4 drop
Tring to find a good backspacing that will put my tires just a bit inside the wheel well, and line up. I am trying to see if you guys have used a combo that works great.
1967 SwB, 454 BB, 4L80E trans, 3.73 eaton posi
1997 C2500 Ext Cab 5.7 Liter
1955 3/4 ton 1st series w/ 235 straight six Sold it
Razor454 is offline   Reply With Quote
Old 03-17-2005, 11:22 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Either a 4 or 4.5 inch backspace should work fine. I would stick with the 8 inch rims, due to better tire selection. You can also get a 9.5 inch wide rim on the back! Do you have any pics of the truck?
Keith
Convert to disc brakes.
Old 03-18-2005, 02:47 PM   #3
Razor454
Razor454's Avatar
Here are a few pictures of what my truck use to look like before I tore it down. It’s roughly the same except for the changes I said previously. The tire combo that I had before the tear down were 15" x 8" Crager deep dish all the way around. These rims had 2.5" of backspacing and kind of stuck out in the front about 1/2", but due to changing all of the front suspension components to New this will change my geometry just a little (wont sag as bad).
Old 03-18-2005, 11:32 PM   #4
lolife99
lolife99's Avatar
Nice truck! Stick with a 4 to 4.5 inch backspace,... and a minimum of a 50 series tire to fill up the fender well. You might look at some of the trucks in the picture section to get ideas.
Keith
Old 03-19-2005, 05:05 PM   #5
Razor454
Razor454's Avatar
Thanks for the advice
After doing some measuring and putting some different combos (BS, widths & sizes) on paper. I think I need a 4.5" BS in the front and a 4" BS in the rear. This will set the tires at 72" rim tip to rim tip while on the truck; this should give me the desired "inside the wheel well" look I am after.
