03-17-2005, 09:06 PM | #1 |
Still drivin' a Rat Rod
Throwout bearing squealing
This is driving me crazy.I put a new throwout bearing in it in Sept.,and it's squealing alreadyIt doesn't do it all the time,mostly when it's cold.Is it possible that it is spinning on the bellcrank,and squealing? I coated it with a thin layer of grease when I put the engine in,could it be dry,and squealing?
If so is there a way to grease the SOB while it's in the truck?I don't want to pull it out,I am going to an automatic in a few months.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
03-17-2005, 11:51 PM | #2 |
I'm not aware of greasable type throw out bearings for most automotive applications. Keep driving it til you get the automatic in. The worst that would happen is it would go all to pieces and the clutch wouldn't disengage. Oh, and do you mean is it possible to be spinning in the clutch fork? I suppose the answer to that could be yes, but more than likely its the bearing itself.
03-18-2005, 12:28 AM | #3 |
Msgt USAF Ret
Do you have the freeplay set at 1 to 1.5 inches so the bearing isn't touching the clutch release fingers and spinning all the time. this would wear out the tb in short order and cause it to squeal. Does the noise change when you engage the clutch to shift?
VetteVet
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
03-18-2005, 09:52 AM | #4 |
My throw out bearing is somewhat new also and when I push in the clutch it sounds like the head of a Rockem' Sockem' Robot (if anyone remembers them) when they pop up but does not make any noise besides that. My mechanic says to run it 'till it fails.
03-18-2005, 09:32 PM | #5 |
I have a couple of inches free travel in the pedal.And yes it does change pitch as I move the pedal.
It becomes nearly silent as it warms up.Well the CD player drowns it out anyway Looks like the automatic is on rush order now,or I'll be totally insane
